Thread: wiring for speedo
  1. wiring for speedo
    Jan 2009
    can any advise about wiring for speedo sensory for Sharan
    wire colour blue/white, black, brown/green. Speedo not working at present
  2. Re: wiring for speedo
    Oct 2007
    what year and which engine code
  3. Re: wiring for speedo
    Jan 2009
    Its a p reg 1996 2 litre cl
  4. Re: wiring for speedo
    Oct 2007
    Black is ignition feed, brown/green is earth, and blue/white to dash panel insert,(speedo)
  5. Thumbs up Re: wiring for speedo
    Jan 2009
    do you have a wiring diagram that shows the wires going into the sensor and the speedo. ie showing where each of the wires go to and from. looking into the engine compartment.
  6. Re: wiring for speedo
    Oct 2007
    On the sensors contact 1 is the black wire,ignition feed
    On the sensors contact 2 is the blue/white wire which runs to the dash panel multistick contact 28/27
    On the sensors contact 3 is the brown/green wire which runs to an earth contact on cyl head
    The wires run from the sensor to a 28 pin connector to the left on the engine,from here they run to the rear of the fuse box
  7. Thumbs up Re: wiring for speedo
    Jan 2009
    thank you for your help speedo now working.
  1. New Speedo
    By baboon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-10-2008, 01:57 PM
  2. speedo
    By FH1 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 29-04-2008, 02:20 PM
  3. speedo in mk2
    By jungleboystu in forum Golf MK2 - 1984 - 1992
    Last Post: 04-01-2008, 10:03 PM
  4. Speedo
    By stuk2000 in forum Passat - Archive Topics
    Last Post: 13-07-2007, 08:48 PM
  5. Speedo way out
    By andrewaudi in forum 80 - 90
    Last Post: 09-03-2007, 11:06 PM
