Thread: V6 Sounds like running on 5 cylinders
  1. V6 Sounds like running on 5 cylinders
    Hello,
    Just took my v6 4motion out and after about 5 mins, the emmissions light came on and the car sounded like it was running on 5 cylinders. Any ideas???
    Many Thanks
    Rich
  2. Re: V6 Sounds like running on 5 cylinders
    May 2007
    have it scaned, i should think that is it? happend to me about 8months ago, emmissions light came on, had it scaned missfire on cyl 5 new spark plug + HT problem solved, about 2 months later running bit bad again, so had them all changed, the cause of the problem for me was broken lambo probes making engine run rich and sooting up sparks, so have a good look at the problem, hope this short bit of info is of help to you.
  3. Re: V6 Sounds like running on 5 cylinders
    Thanks for the info, I've booked it it for a service, hopefully won't be too expensive!
  4. Re: V6 Sounds like running on 5 cylinders
    132 Post(s)
    1980 Post(s)
    Lead on an early V64M and coil pack on a later one.
  1. 4 cylinders or 5?
    By bobthetrain in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 18-03-2008, 08:23 PM
  2. A4 Tdi 110 Bang then running on 3 cylinders
    By finbarr in forum Archive posts
    Last Post: 21-01-2008, 11:11 PM
  3. Mk3 1.8 loss of cylinders.
    By Sollie in forum New Member Introductions
    Last Post: 01-10-2007, 11:30 PM
  4. Replies: 4
    Last Post: 26-09-2007, 02:13 PM
  5. Firing on only 3 cylinders
    By Mozza31 in forum Archive posts
    Last Post: 29-01-2007, 01:32 PM
