Thread: 1995 jetta not starting
  1. 1995 jetta not starting
    Feb 2009
    Not getting power to solenoid wire. Changed ignition switch, still no power. Jumped positive terminal on starter to solenoid switch- nothing. Any suggestions. Can anyone lead me to source on electrical schematic from ignition switch to starter solenoid. Thanks.
  2. Re: 1995 jetta not starting
    Oct 2007
    Hi If you jumped the positive wire to the solenoid and nothing,check the engine earthing strap,if ok,then your starter is faulty
  3. Re: 1995 jetta not starting
    Feb 2009
    Thank You Kenny for your reply. It's not the starter or solenoid. I'm not getting power through the circuit to the solenoid switch. Any ideas has to how to trace circuit from ignition switch to solenoid?
  4. Re: 1995 jetta not starting
    Oct 2007
    The wire runs from the ignition switch to connector H1/1 on the back of the fuse box and out from connector F/1 on the back of the fuse box direct to the starter solenoid. H1 is a red 10 pin connector and F is white 10 pin connector
  5. Re: 1995 jetta not starting
    Feb 2009
    Thanks again Kenny I'll check the circuits. This has been a most frustrating problem and you are the only source I have that knows what you're doing. Thanks Again.
  1. Please Help 1995 Jetta GL (ABA)ECU Troubles
    By bad281 in forum Golf MK3 - 1993 - 1999
    Last Post: 02-07-2008, 03:41 AM
  2. 1995 Jetta Power Steering Problem
    By GeorgerinNH in forum Vento - 1994 - 1998
    Last Post: 09-04-2008, 05:19 PM
  3. Polo 1.3 1995 starting problem
    By redimp in forum Polo - Derby - Lupo - Fox
    Last Post: 30-03-2008, 09:27 PM
  4. A6 2.5 TDI SE (1995) Starting issue
    By M V E Pullen in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 07-01-2008, 04:34 PM
  5. 1995 passat starting problem
    By firefox337 in forum Archive posts
    Last Post: 14-10-2006, 06:43 PM
