Thread: Camshaft Position Sensor (Hall Effect Sensor) - No Signal (G40) :
  1. Camshaft Position Sensor (Hall Effect Sensor) - No Signal (G40) :
    Jan 2009
    help my 96 reg falicea faild its mot on emissions a freind ran a diagnostic and it came back with this code
    Camshaft Position Sensor (Hall Effect Sensor) - No Signal (G40) : would this cause the emissions to fail
    thanks
  2. Re: Camshaft Position Sensor (Hall Effect Sensor) - No Signal (G40) :
    2018 Post(s)
    1.6 AEE engine?
  3. Re: Camshaft Position Sensor (Hall Effect Sensor) - No Signal (G40) :
    Jan 2009
    its a 1300 50kw is all i know
    regds
  4. Re: Camshaft Position Sensor (Hall Effect Sensor) - No Signal (G40) :
    2018 Post(s)
    I have to admit I don’t do a lot of work on these anymore, so I wanted to check my info at work first. They don’t have a cam position sensor on the 1.3 Skoda engine, they have a crank speed sensor and wasted spark ignition. The 1.6 AEE engine has a G40 and doesn’t have a crank sensor. What was the fault code number and what are the emissions readings at idle and fast idle?
  5. Re: Camshaft Position Sensor (Hall Effect Sensor) - No Signal (G40) :
    Jan 2009
    the code was 00515 hall sensor g40 no signal, the car is a 1.3 lxi plus.i havent got the paper work with me at the mo and i wont be back on till sat nigth so ill put it on then
  6. Re: Camshaft Position Sensor (Hall Effect Sensor) - No Signal (G40) :
    2018 Post(s)
    Unfortunately I am a bit stuck for accurate fault code info on the 135 and 136 engines but certainly ETKA confirms that the car doesn’t have a cam position sensor, only a crank speed sensor which I am sure would come up as G28 but I can’t remember the name of the last customer I had in with this problem, as I could look it up if I did. I have had a few play up with this, sometimes it has been the sensor, others I have had a broken wire inside the harness leading to the sensor. Did he do the fault code read with the engine running or just with the ignition on?
  7. Re: Camshaft Position Sensor (Hall Effect Sensor) - No Signal (G40) :
    Jan 2009
    he only had the ignition on , iv now sorted the problem........................................... .................. iv px it for a 54 reg golf tdi!!! what a diffrence. many thanks for your help, its very much apriceated
  8. Re: Camshaft Position Sensor (Hall Effect Sensor) - No Signal (G40) :
    2018 Post(s)
    Carrying out a fault code read on many early systems without the engine running will automatically store a crank or cam sensor error-it is a basic error to make.
  9. Re: Camshaft Position Sensor (Hall Effect Sensor) - No Signal (G40) :
    Jan 2009
    thanks ill let him know for future ref. thanks
  1. 00515 Hall Sensor G40 No Signal - HELP
    By mitov in forum VCDS - General Questions
    Last Post: 12-12-2010, 03:16 PM
  2. Fault code 0203 (Hall effect sensor out of range)
    By Cawte12345 in forum Touran - Sharan - Caravelle
    Last Post: 08-12-2009, 01:37 AM
  3. Please Help Camshaft Position / Hall Sensor 17746 - (G40): Open or Short to Plus
    By thor_wulff in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-12-2008, 12:51 AM
  4. Please Help Hall Sensor VAG 06A 905 161 B Availability
    By doubledeclutch in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-08-2008, 11:32 PM
  5. Question A4 Hall sensor?
    By marty72 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-05-2008, 01:07 PM
