Thread: Touran turbo whistle
  1. Touran turbo whistle
    Jun 2007
    West Sussex
    Just bought an 06 1.9TDI. When starting off I can hear what sounds like the turbo whistle. Is this normal to hear it from inside? I'm wondering if it is actually the turbo or something else in the air system leaking..
    Oct 2006
    Sunny slightly hilly Norfolk
    I've got an 06 TDi 1.9 too. Never heard a whistle inside unless the windows are not done up properly in the rear doors. Mine are wind up and its easy to hit the winders. But you only get that with speed.
    2016 VW Tiguan Match Edition (Nimbus Grey) , 09 Ibiza 1.4 SE SC (Nayara Blue), 2014 Leon 1.2 SE (Candy White).
    Feb 2004
    Yorkshire
    49 Post(s)
    I can hear the turbo whistle on my car when I accelerate with the windows open. I believe it is just the turbo spinning up to speed, but if you think it is too loud, have a quick word with a dealer.
    Stuart
    Stuart l VWAudi Forum
    VW Audi Forum - Founder
    Ways to support the website
    Jun 2007
    On my 06 1.9TDI I can only just hear the turbo when the engine is heavily loaded and accelerating at part or half throttle. But it's got to be very quiet in the car to be able to make it out over the engine.
    If the noise varys with the throttle position then it is the turbo.
    If it's that noticable then you need to get the turbo checked.
    PS> if you want to hear a real engine hum try this: http://www.break.com/index/we-are-the-champions.html
    id say its a normal noise, if you're concerned, pop the bonnet and listen to the engine at idle, listen out for any 'hissing' noises, this can be indicative of a boost leak, its highly unlikely to be a faulty turbo if you can hear it, it is more likely to be a boost leak, could be the smallest of holes in a boost pipe.
  6. Re: Touran turbo whistle
    Jan 2008
    Colchester,Essex
    My touran 2.0tdi (500bhp-I wish ) had whistling noise when i went to for a test drive which i thought is normal for these engines.If it was wistling like after 2000rpm but not too loud it would be normal.I actually bought it and took it for a cambelt change.My mechanic tolf me it doesn`t sound right so i went to vw for 2nd opinion wich was the same.The simptoms were:when u start it from cold u could hear a slight whistle but as the engine goes wormer it needed more revs to whistle but 1500rpm u could hear loud enough inside the car.Changed the turbo and looked at the old 1 the shuft inside had plenty of movement.Funny thing is it was pulling ok,no smoke,good mpg.Currently running it in not going above 2000rpm(apparently should give it about 200miles,not sure but logically makes sence)Cost me £442 with Vat for the unit(recond.)Essex turbos in Witham.
  1. whistle sound from my VW Sharan when cold
    By kimsue in forum Archive posts
    Last Post: 05-02-2008, 01:57 PM
  2. MK3 TDI turbo dying... remap or hybrid turbo?
    By leoninanegg in forum Golf MK3 - 1993 - 1999
    Last Post: 15-06-2007, 08:48 PM
  3. turbo Whistle
    By markclemo in forum Audi A3 - Archive Topics
    Last Post: 23-02-2007, 04:41 PM
  4. Air Induction Whistle
    By JSGTTDI in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 22-01-2007, 06:23 PM
  5. Whistle sound from my VW Sharan TDi when cold
    Last Post: 10-04-2006, 07:04 PM
