Thread: Error in braking system warning light help?
  1. Error in braking system warning light help?
    west midlands
    Hi, for the last two weeks everytime i start the car i get the 'Fault in brake system' warning light with a few annoying beeps on the DIS screen as seen in pic.
    Iv hooked it up to the vag-com software but found no faults...
    After i drive for a few miles the warning will disappear. I have checked the brake fluid level. The braking seems fine. Anybody had a similar problem?
    Thank you
  2. Re: Error in braking system warning light help?
    Jan 2009
    towcester northants
    if its red its levels/pressures pressure switches
    if its yellow its pads worn out or sensor wires
  3. Re: Error in braking system warning light help?
    west midlands
    Quote Originally Posted by towcestervag View Post
    Hi, it is red. So does that mean brake fluid level? which pressure switches may it be? thank you
  4. Re: Error in braking system warning light help?
    Jan 2009
    towcester northants
    could be fluid cap itself
    or check to see if its got a pressure sensor on the side of the brake master cyl
  1. ABS/ESP warning light error
    By thefreak in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-11-2008, 05:36 PM
  2. Warning light - Emissions Control System - on
    By Silver Fox in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 29-01-2008, 02:25 PM
  3. Emission Control System Light Warning
    By OliSmi in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 27-01-2008, 11:23 PM
  4. A4 Brake System Warning Light
    By lastyboy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-03-2007, 12:38 PM
  5. Engine management System Warning light
    By petergregg in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-01-2007, 03:46 AM
