Thread: The quest begins
Results 1 to 10 of 14
  1. The quest begins
    Jan 2009
    I'm looking at buying a Audi A4 1.8t quattro and have about 3.5-4k to spend.
    There is plenty on Autotrader for that price which seem tidy with full service histories etc.
    However can people advise me on what I should be looking for i.e. bad points etc.
    I have a rough idea but i would appreciate if general running costs and MPG figures I could expect from the standard 150bhp and mapped ~200bhp cars will return.
    Phil
  2. Re: The quest begins
    2005 Post(s)
    Oil pressure, oil pressure and oil pressure, a major nightmare on the 1.8T longitudinal installation.
  3. Re: The quest begins
    Jan 2009
    Dublin, Ireland
    Hi. I'm looking at buying an Audi A4 1.8T - but don;t think its a quattro.
    Sorry, i've only just started researching, but when you say to look for oil pressure on the longitudal installation.....
    How? Just by the factory oil gauge? What causes the problems? Oil pump? or wear in bearings etc?
    If the car I'm looking at is not a quattro, does that mean the car is rear wheel drive? and hence no problems with oil pressure?
    I know I sound like I don't have a clue- thats cause I don;t know the audis at all...
    Thanks to anyone who has the patience to quickly educate me!
  4. Re: The quest begins
    2005 Post(s)
    The 1.8T in all VAG cars is prone to sludge formation in the sump which blocks the oil pump pick up, much more so on the Passat, A4 and A6, quattro or not. It is very difficult to check for unless the oil light comes on during a test run.
  5. Re: The quest begins
    Jan 2009
    Dublin, Ireland
    No worries.
    So, if one was to buy a car with 100k miles on the clock, and it seems to be in immaculate condition....
    Would one be well advised to do a couple of filter/oil changes, with say 1000mile intervals, to try and shift any potential sludge? Is there any particular oil additive that one could use, to help the process along?
  6. Re: The quest begins
    Jan 2009
    Dublin, Ireland
    Or perhaps this would make things worse - would pulling the sump off be the best way to prevent?
  7. Re: The quest begins
    2005 Post(s)
    The only sure way to check is to remove and clean the sump which means dropping the subframe down, it is quite a big job.
  8. Re: The quest begins
    Jan 2009
    Is this oil problem a common thing or a rare problem?
  9. Re: The quest begins
    2005 Post(s)
    Extremely common, it caused Audi nightmares in the USA.
  10. Re: The quest begins
    Jan 2009
    Dublin, Ireland
    So, if you own a car, and you've got the know-how, pull the subframe, and the sump, and clean it out?
    I wonder if I can do that in the driveway......
  1. Wheel quest
    By Rustybus in forum Chat - Anything with wheels
    Last Post: 10-04-2008, 07:16 AM
  2. B6 Passat general impressions & the quest for the rattle
    By boggle in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 14-08-2007, 06:38 PM
  3. Work begins
    By madfella65 in forum Audi A4 - Archive Topics
    Last Post: 09-06-2007, 01:25 AM
  4. 2002 A4 Avant interior parts quest
    By Tanuki in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-09-2006, 07:59 AM
  5. An old era ends, a new one begins
    Last Post: 27-07-2005, 08:14 PM
