Thread: gtdi cold start problem?
  1. gtdi cold start problem?
    Jan 2008
    nottinghamshire
    hi the other day when i started the car from cold, the car seemed to rev-up a little bit on it's own (like i started the car with the accelerator slighlty pressed)
    then this morning when i started it from cold it did the same reved-up on it own and the revs stayed pretty high (approx 1200rpm) until it reached around 90 then it dropped to the normal around 900rpm
    has anyone experience any kinda problem like this before?
    p.s the glow plug light seems to stay on for longer too, sometimes upto 5 secs, before it would only take about 2 secs
    are these problems related, any suggestions appreciated
    thanks
  2. Re: gtdi cold start problem?
    133 Post(s)
    1984 Post(s)
    More than likely the coolant temperature sensor is faulty, get a code read done or take a chance and change the sensor. Sometimes a faulty sensor will not show up as a code if the reading given doesn’t seem unusual to the ECU, for example reading 20 degrees lower than it should so the only way to track that is to watch the reading in Measuring Blocks 08 and if you are paying someone to do that it is cheaper to just change the sensor.
  3. Re: gtdi cold start problem?
    Jan 2008
    nottinghamshire
    thanks crasher , if it happens again i will ring you for a plug in
  4. Re: gtdi cold start problem?
    Jan 2008
    nottinghamshire
    its been doing it again all day, even when its warm
    when i start her up she revs upto 2000rpm then back down and settles about 1100rpm, sometimes it will drop back to 900rpm after a drive of about 30 or so
    not sure if it still could be related to the temp sender?
    and the glow plug light sometime takes ages to go off?
    thanks
  5. Re: gtdi cold start problem?
    133 Post(s)
    1984 Post(s)
    The temp sender tells the engines computer what the engine temperature is so it can respond in fuelling, idle control and glow plug strategy. If the signal from the sender is spiky and erratic, the computers response will be to ignore that sensor and go by a base map and by the inlet air temperature. You need a fault code read.
  6. Re: gtdi cold start problem?
    Jan 2008
    nottinghamshire
    alright thanks, how much to plug it in?
  7. Re: gtdi cold start problem?
    133 Post(s)
    1984 Post(s)
    £28.75 inc.
  8. Re: gtdi cold start problem?
    Jan 2008
    nottinghamshire
    be in touch soon thanks....
  1. Please Help Cold start problem
    By cluelessmother in forum Golf MK3 - 1993 - 1999
    Last Post: 12-07-2008, 04:52 PM
  2. Cold start problem
    By jb1978 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-04-2008, 04:26 PM
  3. Cold Start Problem
    By robdcaterham in forum Archive posts
    Last Post: 21-03-2007, 07:24 PM
  4. Cold Start Problem
    By Cam in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 22-01-2007, 03:33 PM
