Thread: fault codes
  1. Cool fault codes
    Nov 2008
    folkestone.kent
    can anybody shine some light on this ? car turned up this afternoon on breakdown truck as a none starter,started and ran ok when we drove it into the garage and still runs ok even on a road test,any help greatly recieved...
    Chassis Type: 1U - Skoda Octavia I
    Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 56 76
    VIN: TMBER41U628537478 Mileage: 142860km/88769miles
    Address 01: Engine Labels: 06A-906-032-AJQ.lbl
    Part No: 06A 906 032 HN
    Component: 1.8L R4/5VT 0001
    Coding: 11500
    Shop #: WSC 31480
    TMBER41U628537478 SKZ7Z0A1003386
    7 Faults Found:
    17545 - Fuel Trim: Bank 1 (Add): System too Rich
    P1137 - 35-10 - - - Intermittent
    16705 - Engine Speed Sensor (G28): Implausible Signal
    P0321 - 35-10 - - - Intermittent
    17796 - Control Module Malfunction - DBW Throttle Monitoring
    P1388 - 35-10 - - - Intermittent
    16955 - Brake Switch (F): Implausible Signal
    P0571 - 35-00 - -
    17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
    P1297 - 35-00 - -
    18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
    P1650 - 35-10 - - - Intermittent
    17978 - Engine Start Blocked by Immobilizer
    P1570 - 35-10 - - - Intermittent
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 1C0-907-37x-ASR.lbl
    Part No: 1C0 907 379 D
    Component: ASR FRONT MK60 0103
    Coding: 0021505
    Shop #: WSC 31480 000 00000
    No fault code found.
    Address 08: Auto HVAC Labels: 1Ux-907-044.lbl
    Part No: 1U1 907 044 A
    Component: CLIMATRONIC C 2.0.0
    Coding: 01000
    Shop #: WSC 31480
    1 Fault Found:
    01272 - Positioning Motor for Central Flap (V70)
    37-00 - Faulty
    Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
    Part No: 1C0 909 601
    Component: 0F AIRBAG VW51 01
    Coding: 12358
    Shop #: WSC 31480
    2 Faults Found:
    00532 - Supply Voltage B+
    07-10 - Signal too Low - Intermittent
    01299 - Diagnostic Interface for Data Bus (J533)
    49-10 - No Communications - Intermittent
    Address 17: Instruments Labels: 1U0-920-xxx-17.lbl
    Part No: 1U0 920 911 C
    Component: KOMBI+WEGFAHRSP VDO V03
    Coding: 19422
    Shop #: WSC 23032
    Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
    Part No: 6N0 909 901
    Component: Gateway K<->CAN 0001
    Coding: 00006
    Shop #: WSC 31480
    Address 46: Central Conv. Labels: 1C0-959-799.lbl
    Part No: 1C0 959 799 B
    Component: 3Y Komfortgerát HLO 0003
    Coding: 00259
    Shop #: WSC 31480
    Part No: 1U6959802D
    Component: 3Y Tőrsteuer.FS KLO 0002
    Part No: 1U6959801D
    Component: 3Y Tőrsteuer.BF KLO 0002
    Part No: 1U0959811D
    Component: 3Y Tőrsteuer.HL KLO 0002
    Part No: 1U0959812D
    Component: 3Y Tőrsteuer.HR KLO 0002
    2 Faults Found:
    00928 - Locking Module for Central Locking; Front Driver Side (F220)
    27-10 - Implausible Signal - Intermittent
    Address 56: Radio Labels: 1J0-035-18x-56.lbl
    Part No: 1U0 035 161 C
    Component: Radio GRO 0001
    Coding: 00403
    Shop #: WSC 31480
  2. Re: fault codes
    Hi Just guessing here,i feel for the terminal 30 supply relay.reading the protocol no communication and low voltage.
  3. Re: fault codes
    Nov 2008
    folkestone.kent
    do you mean the (j533)01299 code,i take it this is a common supply to the can bus
  4. Re: fault codes
    There seems to be an intermittent fault with communication with the drive train and the interface j533 ,if this is due to code 00532,i dont know.There is another possibility and that is code 16705 G28.Try and delate the codes to see if any return.Neither of these two parts cost a fortune so?
  5. Re: fault codes
    Nov 2008
    folkestone.kent
    thanks kenney,will do that today and see what happens,let you know later...
  1. vag-com fault codes
    By j.johnson23 in forum VCDS - General Questions
    Last Post: 23-11-2008, 05:47 PM
  2. Question no fault codes
    By clem750 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-08-2008, 08:12 PM
  3. Fault codes ???
    By ronmcintosh in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-12-2007, 11:58 AM
  4. fault codes.......
    By merrener in forum Golf MK4 - 1999 - 2004
    Last Post: 04-12-2007, 03:16 AM
  5. fault codes
    By zoebunny in forum Archive posts
    Last Post: 19-10-2007, 09:49 PM
