Thread: 1.8t engine or turbo problem
  1. 1.8t engine or turbo problem
    Oct 2006
    bedfordshire
    Has anyone any ideas car has just died on me.
    Engine has just cutout warning on the dash was oil problem
    when looked at the dip stick it is all white water is getting into the oil
    somehow. Lost some water NO OVER HEATHIG.
    Removed the plugs they all look ok may be it could be the head gasket between the oil and water flow and return.
    My question is can the water and oil mix within the turbo is there a seal or is the turbo unit all cast making it impossable for the two to mix.
  2. Re: 1.8t engine or turbo problem
    Pembrokeshire
    22 Post(s)
    could be the oil cooler. these have a habit of breaking and letting water into the oil. they can be pressure tested to confirm the fault, you would need to remove it and take it to someone that can test heads, or if you are that way inclined, use a hose to pressurise it and see if water comes out the oil ports. not sure why it would cause the engine to cut out though, but im sure someone will.
  3. Re: 1.8t engine or turbo problem
    Hi I would say it was the head gasket,Usually when the cooler leaks it has the oppisite effect i.e oil enters the cooling system.Does the engine still turn over,when you try to start it?
  4. Re: 1.8t engine or turbo problem
    Feb 2007
    Manchester
    Head gasket deffo.
  5. Re: 1.8t engine or turbo problem
    Feb 2007
    UK (London)
    I have to agree it sounds like head gasket.
    04 Audi A4 B6 1.8TQ S-Line 190bhp 6 Speed Duel SMIC
    Milltek Exhaust|VMR boost Gauge|SP51 K04-15 Outlaw (K04-23+)|Samco Sport DV|034 Sport CAT|
    To be fitted: B7 RS4 F-Brakes|B5 RS4 R-Brakes|SB Stage4| TT MAF| 380 inj|
  1. Question 1.4 Turbo Engine
    By Rhigour in forum Polo - Derby - Lupo - Fox
    Last Post: 25-01-2009, 06:40 PM
  2. 1.8T turbo engine questions
    By qa15ar in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-07-2008, 04:53 PM
  3. Which engine in My b5 turbo 20v?...
    By Foilpact in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-05-2008, 10:42 AM
  4. what turbo will fit my az engine code tdi
    By fisher72 in forum Golf MK3 - 1993 - 1999
    Last Post: 07-04-2008, 09:02 PM
  5. A4 1.8T AVJ engine and turbo
    By andrew.kearns2@ in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 26-03-2008, 05:09 PM
