Thread: 17608 Boost Pressure Control Valve N240 Mechanical Malfunction
  1. 17608 Boost Pressure Control Valve N249 Mechanical Malfunction
    Aug 2007
    Hook Hampshire
    21 Post(s)
    On a Audi A3 2001, AUM engine with 111K miles, I am getting a fault code 17608 Boost Pressure Control Valve N249 mechanical malfunction. P1200-35-00.
    Having read various posts, many people have lots of fault codes including the above but this is the only one appearing. When clearing the code, and starting the car there no codes appear, but as soon as its reved, the code appears.
    Any ideas please. Thanks
    Audi A7 3.0TDi 2011 180k miles, engine code CLAB 204bhp 2WD
  2. Re: 17608 Boost Pressure Control Valve N240 Mechanical Malfunction
    Jan 2009
    the ecu map value requested boost pressure is not matching actual intake circuit air pressure - may be too high or too low
    the N249 must be changed
    your aum also has map sensor @ smic right side of engine compartment near headlight back shell & directly down about 100mm/4in
    this may also be malfunctioning/no longer reading intake circuit pressure correctly
  3. Re: 17608 Boost Pressure Control Valve N240 Mechanical Malfunction
    Aug 2007
    Hook Hampshire
    21 Post(s)
    Thanks for the reply. I am unlikely to get the car back for a few weeks. Is there any problems driving the car with this fault code. What are the symptons.
    Regards
  4. Re: 17608 Boost Pressure Control Valve N240 Mechanical Malfunction
    Jan 2009
    when valve malfunctions / broken engine turbo boost will fluctuate - I would not drive car in this condition
    it can possibly be brittle rubber hose leaking charge air
    valve + map sensor must be checked
  5. Re: 17608 Boost Pressure Control Valve N240 Mechanical Malfunction
    Dec 2008
    Your turbo is over boosting cos I had the same problem, I suggest you look up Turbo Clinic Uk. They explained what was happening then sorted it out with no more problems, unfortunatly I haven't got there number but i'm sure it will be on the internet.
  6. Re: 17608 Boost Pressure Control Valve N240 Mechanical Malfunction
    Aug 2007
    Hook Hampshire
    21 Post(s)
    Thanks Leadspaul, do you know what they replaced. I am hoping to do the work myself.
  7. Re: 17608 Boost Pressure Control Valve N240 Mechanical Malfunction
    Dec 2008
    I had to send the turbo to them and then they did what ever that was. I don't know exactly what it was that they replaced but something was sticking causing it to over boost I know that much.
  1. Question EGR Valve (N18) Electrical Malfunction
    By blackhove in forum Golf MK5 - 2004 - 2009
    Last Post: 21-10-2008, 12:30 AM
  2. Boost control valve
    By CherryB in forum Passat - B5 Forum - 1997 -2005
    Last Post: 31-07-2008, 08:20 AM
  3. AFN Boost Pressure
    By k dicko in forum Archive posts
    Last Post: 31-01-2008, 09:43 PM
  4. turbo vane cleaning/locating boost control valve
    By justin@justinwa in forum Archive posts
    Last Post: 05-11-2007, 05:34 PM
  5. no boost pressure
    By saw47 in forum Audi A3 - Archive Topics
    Last Post: 09-10-2007, 08:23 PM
