Thread: B&O speakers in Avant vs saloon
Page 1 of 3 123 LastLast
Results 1 to 10 of 26
  1. B&O speakers in Avant vs saloon
    Jan 2009
    Audi info states that A4 B&O sound system has14 high performance speakers
    I'm just wondering whether this differs in the Avant compared to the saloon given the absence of a 'rear parcel shelf'?
    On order: A4 Avant 2.0TFSI S line, metallic, Nav + AMI + cruise (= new tech pack) B&O, DAB, Parking Plus, valcona leather, Phone prep low, interior light pack
  2. Re: B&O speakers in Avant vs saloon
    Dec 2008
    I'm also waiting for a B&O equipped Avant, and I've exchanged some emails with B&O customer care trying to understand the differences to the Saloon version.
    Basically the configuration is the same except for the following:
    • the rear speakers are located in the D-column;
    • the subwoofer is located on the excess space for the spare tire (when choosing the tyre mobility kit instead of a space tyre)
    Tiago
  3. Re: B&O speakers in Avant vs saloon
    Jan 2009
    Thanks Tiago
    It makes sense for rear speakers to be located in D-column.
    Just wondering about sub-woofer location if space saving tyre (default?) present.
    At least it sounds as if Avant is not 'short-changed' on speakers compared to saloon, so sound quality should still be good.
  4. Re: B&O speakers in Avant vs saloon
    Dec 2008
    According to B&O, you can only choose this option if you choose not to have the spare tyre...
    Tiago
  5. Re: B&O speakers in Avant vs saloon
    Jan 2009
    Essex
    A guy on Audiworld asked B&O about the saloon & Avant differences and he got some great info
    Sedan Technical specifications
    Front door & Front/Centre loudspeaker:
    Two 25 mm tweeters
    70mm full-range (centre)
    80mm mid-range +200mm woofers
    Rear Door & Parcel shelf:
    25mm tweeters + 168mm woofers
    Two 80mm full-range + 200mm "free-air" subwoofer that uses the parcel shelf as a baffle (like the A5)
    Avant Technical specifications
    Two 25 mm tweeters
    Rear door and "D" pillar:
    25mm tweeters + 165mm woofers
    Two 80mm full-range
    Luggage compartment:
    A 165 mm subwoofer in an 11L bass reflex ported cabinet placed within the excess space of the spare tyre.
    Amplifiers (for both Sedan and Avant):
    Five 25 watt Class-A/B amplifiers for tweeters, mid-range and centre driver
    Two 40 watt Class A/B amplifiers for rear woofers
    Two 75 watt Class D amplifiers for front bass drivers
    One 150 watt Class D amplifier for the subwoofer
    Specifically regarding the subwoofer differences:
    The Limo (sedan) has a 'free-air' subwoofer that uses the parcel shelf as a baffle. The A5 uses the same principle.
    The Avant does not have a parcel shelf so we opted for a subwoofer in a ported cabinet. The only difference in performance is below 30Hz where the subwoofer port starts to roll off. This will make little difference to the listening experience for 2 reasons : 1. Most music contains very little information below 30 Hz. 2. This frequency area is masked by background noise while driving. The Q5 uses the same principle.
    Of course it is possible to put a subwoofer in a sealed cabinet but the loudspeaker itself needs to be very large (as in the A8 / Q7). A ported cabinet can achieve good SPL at low frequency with a relatively smaller loudspeaker.
    Furthermore, B&O also told me that:
    Both cars are tuned individually as each car is unique. Further there are usually two tunings per car as a car with fabric seats and no sunroof will differ from one with leather and sunroof.
  6. Re: B&O speakers in Avant vs saloon
    Sep 2008
    Quote Originally Posted by ScottyUK View Post
    Two 25 mm tweeters
    Two 25 mm tweeters
    Two 80mm full-range
    Excellent info there scottyuk.
    I can confirm that the bass unit is located underneath the spare wheel in the boot in my b&o avant.
  7. Re: B&O speakers in Avant vs saloon
    Jan 2009
    Hi there all,
    i opted for the B&O system in my car and although the sound quality is excellent i was a bit dissappointed by the plastic grill covers on the top speakers/tweeters in the rear doors,just looks so cheap when you see that all the other main visible speakers have that lovely looking (ive got the B&O system) chrome B&O surround on them. Is it just me or does anyone else feel short changed by these tacky looking grills?
  8. Re: B&O speakers in Avant vs saloon
    May 2008
    Thanks ScottyUK! I'm that "guy" and you saved me the trouble of finding my old post!
    Ben
    2009 Audi A4 2.0T S-Line Avant / 2008 Audi TT 2.0T S-Line Coupe
    Retired: 2003 Ford SVT Lightning / 2001 Ford SVT Lightning / 1993 BMW 740iL / 1990 BMW 535iM / 1986 Porsche 944 Turbo / 1983 Porsche 944
  9. Re: B&O speakers in Avant vs saloon
    Jan 2009
    Essex
    Quote Originally Posted by BMWBig6 View Post
    When I started looking at B8's I went through as much info/forum pages as I could. On AW I think I went back through 30 pages of threads!!
    It's such excellent information, I just had to spread the word.
    Glad to see you over here in the same way I'm over there
  10. Re: B&O speakers in Avant vs saloon
    wrightee Guest
    Please could someone who has an Avant and the B&0 pack tell me where the sub is located? The device under my spare wheel looks like a battery of some sort, not a sub woofer as noted by JOP.
    Many thanks,
    Mark
  1. Question Avant interior into a saloon?
    By teccyjim in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-09-2008, 06:47 PM
  2. B5 saloon springs1997 fit b5 avant 1999 facelift
    By adamss24 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-05-2008, 05:05 PM
  3. 99 A6 Avant Amp location for rear speakers
    By Kiwi Kranker in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 09-03-2008, 10:30 PM
  4. 99 Avant Bootlid handl. Same as saloon?
    By AdamC in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-12-2007, 11:14 AM
  5. 97 avant door speakers?
    By quattro kev in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-05-2007, 08:37 PM
