Thread: 2001 Golf 1.4 16v, Engine Misfire
  1. 2001 Golf 1.4 16v, Engine Misfire
    Jan 2009
    Hi Every1
    I am new here, I have a 2001 golf 1.4 16v that is misfiring in cylinders 1 & 2 according to a trouble code computer. Strangely enough when the car is started cold and driven continously it is absolutely fine, but if left to idle around 8 mins or so, the engine loses idle and the engine goes to limp mode.....hence the misfiring starts....if you turn off the engine and start it again its fine...then afte a few mins or so goes back to limp mode and stays that way...could it be the cylinder valves? so far i have changed:
    coil pack, plugs
    Any ideas?
  2. Re: 2001 Golf 1.4 16v, Engine Misfire
    Dec 2007
    Belfast
    Had much the same problem with my 2001 1.6 16v Golf S.
    After having her plugged into the computer, it turned out that she was misfiring on cylinder 3.
    Had the ignition coil replaced on cylinder 3 and hey presto, problem solved.
    Hope this helps.
    Belfastmark.
  1. BOTTOM ENGINE COVER 2001 SDi GOLF
    By bigbrian123 in forum Golf MK4 - 1999 - 2004
    Last Post: 07-12-2008, 05:39 AM
  2. Please Help Tdi sport 2001 misfire and black smoke!!!
    By FDR in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-11-2008, 10:41 PM
  3. Golf mk2 16v gti misfire shudder misfire
    By paramananthamd in forum Golf MK2 - 1984 - 1992
    Last Post: 22-10-2008, 05:32 PM
  4. cyclinder 1 misfire - 2001 VW Golf 1.9 Tdi
    By soldendorp in forum Archive posts
    Last Post: 13-01-2008, 03:41 PM
  5. engine keeps miss-firing (2001 golf tdi se)
    By sheepsteeth in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 28-05-2007, 05:46 PM
