Thread: Single knock when braking or accelerating...
Results 1 to 10 of 20
  1. Single knock when braking or accelerating...
    Oct 2006
    Hi all,
    Went out in the car today and ended up in standing traffic as usual...
    As it was a nice day, I decided to wind down the windows. Soon after doing so, it became apparent that there was a squeaking noise coming from the N/S front wheel. Also, as we went on... stop - start, stop - start. I started to notice a strange knock when pulling away and again when breaking. Less so on gentle braking. As I have recently had some new wheels fitted. I checked to make sure that the hadn’t worked loose... This was not the case. I can see the discs and pads, between the alloy spokes, they look fair... a bit worn, but not down to the bone... Is it possible the calliper may have worked loose or something here? The noise does sound almost like it is coming from underneath the engine bay.
    If I throw it in reverse and hit 5 mpg then brake hard. There’s a definitive single knock. Then going forward, sometimes there is a single knock on acceleration, but definitely when hitting the brakes. Not forgetting the persistent squeaking noise…
    Any ideas???
    P.S Also went down to Halfords today to get some replacement wiper blades, and to my surprise they don’t sell them for my model… 2001 A4. Is this a main dealer purchase?
    Oct 2006
    Pads can move in the caliper/carrier but not excessively to cause a knock.
    If the wheels are correctly torqued up and are the correct fitment, they shouldn't cause any probs. A worn suspenion part, like a ball joint or pivot could cause a knock.
    Have you got a decent jack? Try jacking it and waggling the wheel tofind any 'play' in the suspension parts. Are get a mate to listen next the wheel when you move.
    Which wheels are they, did you notice the knock before getting them?
    The wipers are Audi's own and you can't get off the shelf wipers from Halfords. They pretty expensive at the dealers, but I got mine from GSF parts (German Swedish French). Its the clip that holds them on. Nice and quick and easy to change, just that you can only get them at the dealers or specialists. The rear one (Avant) I need to get from the dealer as I've tried a few off the shelf types as it just clips in, but they are all too wide or the clip doesn't hold them.
    Oct 2006
    Cheers Dave Avant...
    I have a trolley jack. I'll have a look tomorrow. What exactly should I be looking for? I have tried pulling and pushing the wheel whilst on the ground to see if there is any play and also bouncing on the front wing/suspension to see if the knocking noise happens then, but I couldn't replicate the problem.
    The wheels are RS6 18" replicas, I have had these for about 1 month and the noise has only just started to happen.
    Your right the wipers are easy to remove. I'll try GSF for the parts. It's only the rubber on the drivers side. However, I have tried cutting the refills once before and never again... Easier with the complete unit.
    Mark
    Dec 2006
    in regards to wipers...
    im not sure where you guys are from.. but i always go to Andrew Page who supply BOSH wipers and get them at trade price..
    The Audi ones are BOSH but just come in the audi box...
    It cost me £15.99 for the better ones pair.. (theres 2 options)
    RiCKT
    Oct 2006
    Quote Originally Posted by dieselmonkey View Post
    Mark
    Try grabbing it and giving it a good waggle laterally and vertically. Or on ball joints I have used a big screw driver or jack handle, stuck it between suspension parts and as they say in America - Levered it to see if there is any play.
    Oct 2006
    Quote Originally Posted by RickT View Post
    RiCKT
    Just over t'other side of Pennines. The wipers I got were £15 (Pair), not Bosch, but German, can't remember the name. Might remeber Andrew, seen one his vans around here.
    Aug 2006
    Devon, UK
    Could also be the cv joints or wheel bearing, though thats probably less likely than a worn bush.
    Passat Sport Estate 2001 1.9 TDI PD
    100k miles
    Oct 2006
    Hi all...
    Well some good news...
    First off got the wipers sorted... Called Andrew Page but they confirmed my fears that the 2001 on model has to be sourced direct from manufacturer. Called local Audi dealer, they charged me £17 for driver’s side - £14 for passenger... Done and dusted now...
    As for the knocking noise... Well this got considerably worse over the last couple of days... Checked the wheel nuts, but to no avail... Tight as you like.
    Now a noticeable vibration was evident at high speeds... Now certain it was pointing towards a dodge driveshaft, I jacked it up on the passenger side and shook the wheel around… And to my amazement the bloody thing was all over the show.
    Still unable to move the wheel nuts… I dropped it and loosened all the nuts. Jacked it up again and removed the wheel. The brake disc was rocking around, but according to the Haynes manual, this is normal. They are held in place by the wheel nuts.
    Cleaned out the threads with a bit of WD and re-fitted the wheel… Now the wheel is tight up against the hub, all suspicious noises eradicated.
    My concern now is that, there could be some unseen damage to the wheel and or hub… Is this possible, everything looks ok…
    I'd say that if it's all tight now and there's no noise you've gotten away with it guv.
    If the wheel bearing was away then you'll hear a distinct rumble from it.
    If the wheel was dameged then you'ld feel it.
    If all is quiet and smooth then karma has been restored.
    Canada
    I agree niall76, the wheel holds the disk to the hub, the hub is held inplace by the hub nut.
    Rob
  1. fan noise when accelerating????
    By need help in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-12-2007, 10:19 PM
  2. A4 B5 Dash Conversion - single DIN to Double DIN
    By milesperhour in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-03-2007, 03:21 PM
  3. Serious Braking Problem
    By rapster01 in forum Archive posts
    Last Post: 03-03-2007, 11:07 PM
  4. Braking Buzz!
    By robstocker in forum Passat - Archive Topics
    Last Post: 13-02-2007, 09:26 AM
  5. Ipod connection to Gamma with single CD and changer
    By curph in forum Passat - Archive Topics
    Last Post: 10-01-2007, 06:15 PM
