Thread: VW Passat low engine temp
  1. VW Passat low engine temp
    Jul 2008
    I have 2002 V6 TDI Passat 4 motion TDI Tiptronic. It has a mileage of 160,000km about 10,000kms ago the engine coolant temperature started to drop below 90oC (it has been rock steady for 3years at 90) to about 85oC particularly when I was driving it down hills and on flat motorways. The temperatrure reads down to 80oC when coasting down long hills.
    The timing belt was changed at 125,000 with the water pump but not the thermostat.
    Questions:
    1. Is it ok to run it with this problem until the next timing belt change 250,000 and then change the thermostat with the water pump.
    2. Could it be another fault ie: the coolant fan staying on permantley or something else.
    I am worried that the engine is running to cold and will not burn the fuel efficiently and may cause the turbo and injectors to fail due to incorrect burning of the fuel.
    Thanks.
    PJCL
  2. Re: VW Passat low engine temp
    Hi You will need to find out if it could be the temp sensor,or the gauge,that could be at fault.So the first thing you need to do is measure the coolant temperature.
  1. Engine Temp
    By burpf1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-09-2008, 06:53 AM
  2. Engine Temp Light
    By rmtebbot in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-06-2008, 10:26 AM
  3. TDI Engine Temp
    By tdi alastair in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-05-2008, 10:17 PM
  4. Engine temp.
    By barryG in forum Early Passat Forum - Pre 97
    Last Post: 12-05-2008, 11:01 PM
  5. Engine Temp
    By Dan80 in forum 80 - 90
    Last Post: 22-03-2008, 01:25 PM
