Thread: Front brake disc min thickness T4
  1. Front brake disc min thickness T4
    Jan 2009
    First post; Does anyone know what the minimum thickness is for a front disk on a '94 Transporter before the disk needs replacing?
  2. Re: Front brake disc min thickness T4
    If its an orginal disc its usually marked on the disc near the bolt holes.
    chris
  3. Re: Front brake disc min thickness T4
    Pembrokeshire
    22 Post(s)
    vented discs, 20mm. solid discs, small 13mm, larger<6/7x15> 15mm. hope this helps.
  1. Front brake disc advice
    By PeteK in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-01-2009, 06:58 PM
  2. Front Brake disc size on a 1.6 se
    By mfosbrook in forum Golf MK4 - 1999 - 2004
    Last Post: 27-02-2008, 09:24 PM
  3. Binding Disc Brake...Hot front wheel
    By onzarob in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-02-2008, 10:44 AM
  4. Front brake disc (FS-III)
    By Jackjack in forum Golf MK4 - 1999 - 2004
    Last Post: 04-09-2007, 11:26 PM
  5. Front Brake Disc Size for Bora TDI 115bhp?
    By Jugga in forum Bora - 1998 - 2005
    Last Post: 16-05-2007, 09:35 PM
