Thread: Disconnecting battery
  1. Disconnecting battery
    May 2007
    Evening all
    I'm going to disconnect and remove my battery this weekend so that I can check for any blockages in the drain holes beneath it.
    I realise the stereo will require re-setting with the code, but is there anything else that I need to be aware of?
    I seem to remember something about the ECU re-setting if the battery is disconnected for more that half an hour??
    Thanks in advance for any advice...
  2. Re: Disconnecting battery
    Turn everything off including the A/C then disconnect. Make a sharp reconnected and then when you turn the ignition on wait 10 seconds before starting. All should just be fine. Regards Peter
  1. Replies: 6
    Last Post: 11-12-2008, 07:16 PM
  2. Help! strange behaviour after disconnecting the battery
    By V8000 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 13-08-2008, 11:04 PM
  3. Disconnecting the Aux Cabin Heater
    By Mozz in forum Alhambra
    Last Post: 08-06-2008, 07:06 AM
  4. Disconnecting A3 Subwoffer
    By Jak123 in forum Audi A3 - Archive Topics
    Last Post: 05-03-2008, 12:12 PM
  5. Does disconnecting the battery clear the error codes/logs ?
    By MiKe_T in forum Passat - Archive Topics
    Last Post: 22-01-2007, 09:00 PM
