Thread: Golf IV TDI Map sensor location
  1. Golf IV TDI Map sensor location
    Feb 2007
    Hi I own a 2002 mk IV golf with the 150hp engine, could anyone tell me where the MAP sensor is located and if it's possible to check it out?
    Thanks you
    Quote Originally Posted by smoker View Post
    Thanks you
    MAP sensor? do you mean the MAF ie the Mass Air Flow sensor?
    if so, its attached to a pipe, on the top half of the air box, its dead easy to spot and simply unplugs
    7 Post(s)
    No, there is a MAP sensor 'Manifold Absolute Pressure' sensor as opposed to a MAF 'Mass air flow' sensor.
    On the 115's and 130's this is a combined sensor with the inlet air temp sensor and sits on top of the side mount intercooler. On the 150 I think it would have to be somewhere on one of the boost pipes.
  1. mk3 golf speedo sensor?
    By BugsyMalone666 in forum Golf MK3 - 1993 - 1999
    Last Post: 27-06-2009, 11:09 PM
  2. fuse location for radiator fan on mk4 golf
    By elliotta44 in forum Golf MK4 - 1999 - 2004
    Last Post: 15-06-2007, 07:36 AM
  3. fuse location for petrol locking cap golf mk4
    By stejuk in forum Golf MK4 - 1999 - 2004
    Last Post: 31-05-2007, 07:09 PM
  4. Airbag Sensor location ???
    By MrSpiffy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-04-2007, 07:25 PM
  5. Golf V5 oil pressure switch location???
    By neil b in forum Golf MK4 - 1999 - 2004
    Last Post: 16-03-2007, 05:40 PM
