Thread: Rapid Coolant Loss and Coolant Alert
  1. Exclamation Rapid Coolant Loss and Coolant Alert
    BigSMan Guest
    Hey - i've had my golf for about 2 months and everything was fine after service, i was just told it may need a new exhaust which i may consider soon - but what i have noticed alot recently is the coolant alert keep bleeping so i check my level and its empty so i fill it with water - now this is fine except the past 2-3 days its been constantly beeping and constantly losing coolant, now i think there is a leak - can anyone tell me what maybe the problem and what i should do next - im scared it may be the radiator or head gasket and im a poor student lol - also if i should get it checked out where should i go? would kwik fit be ok? thanks guys
  2. Re: Rapid Coolant Loss and Coolant Alert
    Southern County Softy
    20 Post(s)
    Get it pressure tested to find the leak, then fix the leak.
    I wouldn't take my car to kwikfit, find a local VW specialist.
    A4 2.5 tdi QS (mapped)
  3. Re: Rapid Coolant Loss and Coolant Alert
    BigSMan Guest
    Quote Originally Posted by kite View Post
    appreciate the fast reply mate - i will try and find my nearest specialist
  4. Re: Rapid Coolant Loss and Coolant Alert
    Southampton, UK.
    Pray it's the rad and not the head gasket. If it is the latter, you'll get mayo on your oil filler cap. That is an indicator that the gasket has gone, though not a 100% bet, as it can happen if the oil cooler goes too.
    2003 VW Golf Est 1.9 TDI 130 (gone but not forgotten after 379,000 miles)
    2006 Audi A3 2.0 TDI Sport 140
  5. Re: Rapid Coolant Loss and Coolant Alert
    BigSMan Guest
    Quote Originally Posted by herby0001 View Post
    i have some sort of mayo on my oil cap :'( handed it in garage should find out soon what the problem is
  1. t5 coolant loss
    By chris_bograt in forum The Commercial Range
    Last Post: 26-09-2008, 09:07 AM
  2. t4 coolant loss
    By Steve06 in forum The Commercial Range
    Last Post: 28-02-2008, 11:10 PM
  3. tdi pd coolant loss
    By abbottgaz in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-02-2008, 11:28 PM
  4. coolant loss
    By jess james in forum The Commercial Range
    Last Post: 11-01-2008, 06:00 PM
  5. Coolant loss?
    By daveac41 in forum Polo - Derby - Lupo - Fox
    Last Post: 11-11-2007, 03:22 PM
