Thread: Fuel Injector failed Urgent advice needed please!!
  1. Fuel Injector failed Urgent advice needed please!!
    Mar 2008
    Hi frds,
    Today in snowy Monday my 55 Reg 2.o ltr passat broken down again not the fuel pump failure this time instead I was told by passat dealer it is a fuel injector's fault.
    To my worse nightmare the expected bill is over £800 minimum (could be more if more fault dignosed after injector changed).
    I am really annoyed because of unexpected costs and all un-reliability of passat. Who know next day it is turbo failure or anything else
    Now I seek advice from other users who have similar problem in past. What did you do? Is this work can be done from some independent garge? I live in Manchester. So could anyone suggest a VW specicialt in Manchester who can do this job on much cheaper.
    My car is still with dealer but I have not requested change yet because I wanted to check my options first.
    Thanks for your help.
  2. Re: Fuel Injector failed Urgent advice needed please!!
    Scunthorpe
    Is it worth trying to source one from a scrapyard or ebay - then getting rid of your Passat (sacriliege I know)!
  3. Re: Fuel Injector failed Urgent advice needed please!!
    Norfolk
    Make sure it is an injector fault and not a faulty wire loom to the injectors.The loom is expensive to replace but a decent autoelectrician should be able to patch repair it for you.
  4. Re: Fuel Injector failed Urgent advice needed please!!
    Apr 2007
    France
    12 Post(s)
    1996 Laguna 2.2D
    1977 MGB roadster
  5. Re: Fuel Injector failed Urgent advice needed please!!
    hrfc Guest
    I have an 05 Passat 140, the in tank fuel pump went in April 08, then had recurring fault where the vehicle would go to 'limp home mode', a new loom injector fixed that problem,but 2 weeks later the car lost all power on motorway and have been told by garage that it may be the engine ECU
    As Martin said make sure it is not the loom before getting the injectors replaced, also find an independant VWSpecialist as they wil be able to half your bill whilst still using genuine VW Parts
  1. Urgent advice needed - A6 2.5 TDI
    By BobA6Avant in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 01-06-2008, 11:08 AM
  2. Looking at Buying 99' 1.6SE - urgent advice needed!
    By mak1 in forum Golf MK4 - 1999 - 2004
    Last Post: 06-01-2008, 07:13 PM
  3. Urgent Advice Needed
    By Alun in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-12-2007, 07:37 PM
  4. Urgent.. fuel injector pump pressure figures
    By baloo in forum Archive posts
    Last Post: 29-08-2007, 05:48 PM
  5. urgent advice needed
    By ANDYA4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-07-2007, 09:55 PM
