Thread: MOT Emissions Failed
  1. MOT Emissions Failed
    Aug 2008
    Ipswich
    Hi guys looking for ideas my car has just failed Mot emissions and am looking for your help as to possible causes.
    Its a 1.4 16V AHW mk4 Golf 1998 with 100k
    O2 sensor passes the test but CO fails @ about 0.60 and HC fails at about
    260
    New Cat fitted and new O2 sensor due to O2 low voltage DTC.
    Any ideas??
    Cheers Andy
  2. Re: MOT Emissions Failed
    meathead Guest
    In the past I've seen that changing the oil and filter will allow the car to pass the emissions test. Try that.
  3. Re: MOT Emissions Failed
    could be a WEAK spark plug not firing properly or a lead on the way out . hc is unburnt fuel . id suggest new plugs , oil and air filter , take the car for a good thrash before driving into the mot bay . cat will be cherry hot and you should see a pass hopefully.
    what were the lambda readings ????
  4. Re: MOT Emissions Failed
    Aug 2008
    Ipswich
    Lambda reading was 1.020 and I have had a service not two weeks ago that included NGK plugs and an air filter .
  1. A6 2.8 Quattro - Failed MOT on Emissions
    By dforsdike in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 20-12-2008, 02:18 PM
  2. Failed Emissions
    By alexmcc in forum Golf MK3 - 1993 - 1999
    Last Post: 15-03-2008, 05:26 PM
  3. Failed on emissions ?
    By mark2004uk in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 13-01-2008, 10:03 AM
  4. Passat 1.8 non turbo failed MOT emissions for CO
    By JHT in forum Passat - Archive Topics
    Last Post: 11-10-2007, 12:44 PM
  5. A4 20v non turbo ADR 1998 emissions failed
    By bullet in forum Archive posts
    Last Post: 24-03-2007, 11:01 AM
