Thread: Rns E Mode Button Not Working
Page 1 of 3 123 LastLast
Results 1 to 10 of 27
  1. Rns E Mode Button Not Working
    Aug 2008
    I recently bought a RNS E and it is working fine. However the direction do not show up in the display between the clocks and the MODE button doesnt work either. Is there anything I can do to resolve these issues?
  2. Re: Rns E Mode Button Not Working
    Southern County Softy
    20 Post(s)
    Is this a retro fit, do you have colour or red DIS.
    With a route selected you can turn the unit off then back on, that should give you arrows on the DIS
    A4 2.5 tdi QS (mapped)
  3. Re: Rns E Mode Button Not Working
    Aug 2008
    It is a retro fit. The display is red only. The radio info comes up ok but not the Nav info. I will try turning the system off and on with a route selected. however the mode button still wont work. I have been reading that the car may need to be programmed so that it recognises the fact it has a Nav system now, do you know if that is correct?
  4. Re: Rns E Mode Button Not Working
    20 Post(s)
    The car does have to be coded for nav.
    The on and off trick is to overcome the red dis "bug"
  5. Re: Rns E Mode Button Not Working
    Aug 2008
    ok thanks for the info.
    Can this be done by an Audi garage?
  6. Re: Rns E Mode Button Not Working
    20 Post(s)
    Have a look in the "vagcom" section for a member near to you, they maybe able to help.
  7. Re: Rns E Mode Button Not Working
    Aug 2008
    Ok will do, where is it on the site? Am new here.
    Another problem is that I am working in France right now and so would need to find someone out here!
    Would an Audi Garage do it do you know?
  8. Re: Rns E Mode Button Not Working
    20 Post(s)
    You could ask your local dealer.
    vagcom section............https://www.vwaudiforum.co.uk/forum/s...ead.php?t=5319
  9. Re: Rns E Mode Button Not Working
    Aug 2008
    Yea the car has to go in for a service soon so will give it a go. It should be fun trying to explain it to them! However I dont really see a problem. If I bought the unit from Audi and they fitted it surely they would have to reprograme the car so that it would work properly. What do you recon?
  10. Re: Rns E Mode Button Not Working
    20 Post(s)
    Dealer will tell you that the RNS-e cannot be retro fitted.
  1. Question A4 RNS E retrofit MODE button doesnt work
    By Andyrhicks in forum In Car Entertainment
    Last Post: 18-01-2009, 08:39 PM
  2. Diesel - turbo working slightly - not limp mode
    By carlsbergy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-07-2008, 09:31 AM
  3. "Button not working"?!?
    By brianthornton in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-04-2008, 08:42 PM
  4. Replies: 0
    Last Post: 02-11-2007, 05:36 PM
  5. 2 button and 3 button fobs / remotes
    By Loofer in forum Archive posts
    Last Post: 07-08-2007, 02:08 PM
