Thread: Ignition Control Module - Passat 1.8 20v turbo 1998
  1. Ignition Control Module - Passat 1.8 20v turbo 1998
    Nov 2008
    Question 2 plugs, 1 either side of ignition control module, 1 has 5 pins other has 4 pins....
    Do they all go to the 4 coil packs which are 3 pin plugs...?
    Problem is its either my lead going to coil 2 is knackered as im not getting spark there, or the module's gone.... dont wanna pay for lead and module..
    the plug that goes to the coils has 3 female pins which when testing 2 of the pins theres voltage 12v when ignition on and 14.2 when engine running, the 3rd pin has no voltage engine on/off, but the other 3 coil plugs no. 3 pin has a voltage of 0.53-0.62 when engine running...
  2. Re: Ignition Control Module - Passat 1.8 20v turbo 1998
    Nov 2008
    Any help to which part i need would be great
  3. Re: Ignition Control Module - Passat 1.8 20v turbo 1998
    Nov 2008
    I found a good read up on how to test the ignition module on audiworld good write up and photos for novices like my self, tested the unit and no its now faulty which i can now go and buy with confidence knowing thats my problem
  4. Re: Ignition Control Module - Passat 1.8 20v turbo 1998
    london/ UK
    I was just about to advice you to swap with a known good lead and coil...You just figgured out yourself...Well done !
  1. Passat comfort control module harness repair
    By redman in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-05-2019, 07:09 AM
  2. Passat 1.8 20v Turbo 1998, ignition problems
    By vwpassat1.8juic in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-01-2009, 10:49 AM
  3. Question How to program comfort control module for VW Passat
    By justscottish in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-01-2009, 07:59 PM
  4. Audi A4 (1998) Cruise Control Module wanted
    By quethiock in forum Chat - Anything with wheels
    Last Post: 10-10-2008, 03:02 PM
  5. ABS control module 1998 VW Passat GLS 1.8L turbo
    By adrian537 in forum Chat - Completely Off Topic
    Last Post: 13-11-2007, 11:02 PM
