Thread: Mk3 Golf radio turns off with ignition on!
  1. Mk3 Golf radio turns off with ignition on!
    Jan 2009
    Hi, I have a 3 door, P registration Mk3 golf gti, 8v model. There is a bizarre problem whereby the radio turns off when the igniton is turned on and turns on again when switched off (with key still inserted). When the key is removed it turns off again.
    I have tried a different head unit with the same problem and checked all the fuses. Any ideas to a solution would be great, long journeys are becoming very tedious!
    Simon
  2. Re: Mk3 Golf radio turns off with ignition on!
    On the 8-pin connector, on the radio,check the power on the white on red wire should be 12v,with ignition off.Check the brown on red wire 12v with ignition on and 0v when the key is out
  3. Re: Mk3 Golf radio turns off with ignition on!
    Nov 2010
    Dublin
    Quote Originally Posted by sjb-123 View Post
    Simon
    I have a similar problem to this one you reported. With the ignition on, my radio turns off. With the ignition off(key in or out), the radio turns on. I've discovered that if I disconnect the ACC lead, the radio will turn on so this may be a possible workaround but I'd prefer that the radio would turn off when the ignition is turned off.
    Did you find a solution to your problem?
  1. Question CDR 300 radio turns itself on
    By SimbowVW in forum Golf MK5 - 2004 - 2009
    Last Post: 19-06-2011, 11:03 AM
  2. Ignition or Radio Live?
    By eeyore in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 19-01-2009, 09:34 PM
  3. Mk3 Golf turns over but doesnt fire
    By vdubber73 in forum Golf MK3 - 1993 - 1999
    Last Post: 23-10-2008, 11:23 PM
  4. Radio Ignition live fuse
    By owend in forum Golf MK4 - 1999 - 2004
    Last Post: 24-08-2008, 10:16 AM
  5. Golf Mk3 ignition knock
    By Handsolo in forum Golf MK3 - 1993 - 1999
    Last Post: 01-08-2007, 01:09 PM
