Thread: tempreture gauge problem
Results 1 to 10 of 16
  1. tempreture gauge problem
    Mar 2007
    Hi just got a 2002 a4 1.9 tdi, The tempreture gauge will sit at the correct half way mark the just drop to zero, and sometimes not even work at all, Car run's fine and doesent over heat.
    I think myby it need's a new tempreture senser fitting but not sure.
    Also noticed some funny electrical robotic like noise from behind the dash, It is like something is trying to set in position, myby it's the climate control, Also climate control seems a bit tempremental.
    Any advice on the above will be muchly appricaited, Thank You.
    Feb 2006
    Reading, UK
    Temperature problem will be the sender unit, cheap and easy to replace. 'tis a pretty common problem, and a two minute fix. Perhaps you could get the climate control robot to do it for you?
    B5 2000 1.8T Sport Estate
    178,000 miles and counting..
    Mar 2007
    thank's dave
    Mar 2007
    Coventry
    Hi, I've just bought an A4 2.0 FSI '52' reg with the same simptoms, including the continual climate adjustment noise you have described. I've just bought a new engine temp sensor from Audi at £27 I'll let you know if it works.
    Feb 2006
    Reading, UK
    Excellent - good luck with it. The temp dial is almost certainly the sender unit.
    Feb 2007
    northeast
    yer my 99 tdi was doing saame thing with temp gauge so i took the sensor out n cleaned the pins inside the sensor and had no more problems, just genly scrape the pins with a small screwdriver or nail file squirt wd 40 on and it should be fine
    Mar 2007
    Lancashire
    My 2001 1.9TDi has the same issue. I replaced temp sender but it didn't cure the problem. Is there anything else that can be checked? If not I'm going to live with it. Too costly for a replacement gauge!!
    Dec 2006
    this should be reported in VAG-COM under the cluster section and tell you waht the faults is..
    RicKT
    Feb 2007
    wicklow, Ireland
    Hi Guys,
    I seem to have the same problem with my newly aquired '03 TDI SE. can anybody direct me to where the temp sensor is mounted.
    Thanks,
    Nigel.
    Mar 2007
    Lancashire
    Audi forums are littered with faulty temperature gauges. The Audi TT had dashboards replaced as so many failed. My personal opinion is that there cannot be so many faulty temp senders but faulty gauges. I could be wrong but I've head from other websites that it didn't fix. Someone one selling temp gauges on their own. Not sure I fancy stripping the dash.
    It's worth replacing sender as they do fail and it could cure the problem.
  1. Oil Temp Gauge
    By rob1380 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-02-2008, 09:01 PM
  2. Temp gauge/cooling problem
    By harrier22 in forum 80 - 90
    Last Post: 28-05-2007, 12:29 PM
  3. Audi Coupe Fuel Gauge Problem
    By AUDIMAN in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 13-05-2007, 11:51 PM
  4. mk 4 golf temperature gauge problem
    By stusus83 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 25-02-2007, 11:31 PM
  5. TEMP GAUGE
    By GARY in forum Passat - Archive Topics
    Last Post: 30-11-2006, 05:14 PM
