Thread: still having problems , turbo not kicking in
Results 1 to 9 of 9
  1. still having problems , turbo not kicking in
    Nov 2008
    hi, I'm still having problems... i changed upper inter cooler pipe, loose fitting,to no avail.
    found a hole in the solid vacumn pipes. this i believe has stopped it going into limp mode , as it has not done it since.
    the whistling noise is still present
    economy down by about 20%
    put the foot down a little the other day here's what i got in 3rd gear
    2500 rpm 40mph
    3500 rpm 60-70 mph
    i can not feel the turbo kick in although i can hear a whistle at about 1200 rpm
    there are no signs of damage to the turbo,no oil, no smoke,even when i floor it.
    i drove it about 30 mins ago and in third from 2000- 3500rpm i felt no sudden increase in power
    this has led me now to think that it may be a turbo fault
    it is throwing no codes up whatsoever.
    anyone got any ideas?
  2. Re: still having problems , turbo not kicking in
    Nov 2008
    forgot to mention 1.9 tdi sport avf engine code.
  3. Re: still having problems , turbo not kicking in
    Gwent
    My AVF was doing something similar, however the boost was coming in hard at higher rpm in the lower gears, by the time I was hitting 3500 rpm in 3rd 3rd it would generally go into 'limp mode' triggering an overboost code.
    Can you go into measuring blocks with Vag com and check the MAP sensor?
    I did this and was not happy with what I saw. New sensor was £38 +vat
    Worth looking into before you do the turbo imo?
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  4. Re: still having problems , turbo not kicking in
    Nov 2008
    i have a geniscan gs200 but it doesn't throw out any codes, i unplugged the MAP sensor, it threw up 2 codes, i plugged it back in and deleted the codes and they haven't appeared again, therefore i presume the map sensor is ok.
    the noise i have coming through the exhaust is only heard through the intermediate box,which increases with the engine speed.
    another thing i've noticed is when i get out of the car i can smell very strong fumes straight outside the drivers door, could it be the cat that has gone?would that show up on an emissions test?and what kind of noise would it make? you can't hear the noise on idle.
    i have the sound on my pc but i can't attach it to this.
    if anyone can help, i'll send them it so that they could listen to it....
    cheers
  5. Re: still having problems , turbo not kicking in
    Gwent
    For what it's worth, mine did not give a code for the MAP sensor at all, only for overboost which was being caused by the MAP sensor.
    If you only got this problem when the noise appeared (as said in your other thread) then you need to get to the bottom of that first. Maybe try to pressure test the intake system? I.e. disconnect and plug the boost hose from the turbo and disconnect the other end from the manifold fit some kind of adapter and see if it holds say 10 psi?
    If leaking, you should be able to find where from
    Why not post the noise on youtube and link it on here?
  6. Re: still having problems , turbo not kicking in
    Huddersfield, West Yorkshire.
    I have the same car with a similar problem and i get two codes for the MAP sensor, i did believe the MAP sensor was in the ECU on these otherwise i do not no where it is?
  7. Re: still having problems , turbo not kicking in
    Jul 2008
    Can you disconnect the boost pipe and visually check that the turbo is spinning and not jammed?
  8. Re: still having problems , turbo not kicking in
    Gwent
    Quote Originally Posted by discobarry View Post
    MAP sensor is mounted on the hard plastic intake pipe accross the back of the engine. (Just in front of the battery area).
  9. Re: still having problems , turbo not kicking in
    Nov 2008
  1. VW Passat Tdi Sport 130 2002 - Loss of Power - Turbo not kicking in
    By iworld in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-11-2013, 07:34 PM
  2. Fan kicking in on start up and now emissions light on
    By zxrmatt in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-09-2008, 09:20 AM
  3. ABS Kicking in at very slow speeds
    By angrydad in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-04-2008, 08:11 PM
  4. Turbo problems?
    By Gracie in forum Golf MK4 - 1999 - 2004
    Last Post: 18-02-2008, 12:52 PM
  5. Polo overheating - fan not kicking in.
    By polo 91 in forum Polo - Derby - Lupo - Fox
    Last Post: 06-01-2008, 10:21 AM
