Thread: A2 TDI rough running until warmed up
  1. A2 TDI rough running until warmed up
    2001, fully serviced, just passed through 70,000 miles
    This morning the wife complained that the car was "Kangarooing" Went to go to work this evening and still running rough and now the ABS light and traction control warning lights were on. Swapped cars and after a while the fault dissapeared.
    Just started the car from cold and all seemed fine then the rough running and warning lights appeared. Took the car out for a drive and it did not seem like it was running on all cylinders. Just before the engine reached normal water temp I pulled over and switched off. Waited a while and started her up. No warning lights but still a bit lumpy. After a short while the car reached normal running temp and the engine was then running like a dream.
    Anyone with any ideas
  2. Re: A2 TDI rough running until warmed up
    Feb 2007
    Ideally you should get the car checked for fault codes.I had a similar problem with my polo tdi which i believe is the same engine.Turned out to be the injector wiring loom.
    Regards
    djl
    '12 Audi A4 Allroad 2.0 TDI 'CGLC'
    '11 VW GOLF BLUEMOTION 1.6 TDI. 'CAYC'
    '07 VW T5 TRANSPORTER T32 ,,,,,, 'BNZ'
    '91 VW GOLF SPORTLINE CABRIOLET 1.8 GTI. 'DX'
  1. S3 rough running
    By jwood662 in forum Audi A3 - Archive Topics
    Last Post: 10-12-2008, 06:59 PM
  2. 1.8 8V running rough.
    By sportline in forum Golf MK1 - 1974 -1984
    Last Post: 28-04-2008, 10:05 PM
  3. Mk3 GTI 8v - Rough running
    By scorchi0 in forum Golf MK3 - 1993 - 1999
    Last Post: 31-12-2007, 02:25 PM
  4. Rough running
    By andrew.butler57 in forum Golf MK3 - 1993 - 1999
    Last Post: 22-11-2007, 04:08 PM
  5. Beetle Rough Running
    By dantheman in forum Beetle 2000-
    Last Post: 27-10-2007, 10:51 AM
