Thread: help a newbie
Results 1 to 10 of 10
  1. help a newbie
    Jan 2009
    hi i have w reg passat 1.8 20v turbo (apu engine).the car will start but wont rev smoothly and it wont idle,ihave to pump on the pedal to keep it running or it will cut out.it sounds verry spluttery!!!! can anyone point me in the right direction please.
  2. Re: help a newbie
    134 Post(s)
    2005 Post(s)
    You need to get it to a garage for a fault code read to see what is stored. I imagine it will be a faulty coolant temperature sensor which is cheap and easy to do.
  3. Re: help a newbie
    Jan 2009
    thanks crasher, will do that tomorrow.i just dontwant to go to a garage completely blind!
  4. Re: help a newbie
    Jan 2009
    i replaced the temp control sender today,still the same!so got it scanned,1 fault,lambda sensor but the mechanic didnt think this is causing the problem,he thinks it isnt getting enough fuel?when i got it home i kept it running to get it up to normal temperature i noticed a rattling coming from the engine(top) but its only there between 3 and 4000 revs,after 4000 it dissapears,and wont rev past 5000.inoticed it seems to run a lot smoother when hot. anyone have any ideas?????????????????
  5. Re: help a newbie
    Jul 2008
    Well the ECU uses the lambda sensor to balance the fuel mix - so could be!
  6. Re: help a newbie
    Jan 2009
    the mechanic said" the lambda doesnt start working till the engine is hot" but if you say its helps to regulate fuel,would a lac of fuel cause a rattling noise between 3000 to 4000 revs?????
  7. Re: help a newbie
    134 Post(s)
    2005 Post(s)
    There is more than one lambda sensor code for a 1999 APU engine
    P0130 16514 Bank 1 probe 1 electrical fault in current circuit
    P0131 16515 Bank 1 probe 1 voltage too low
    P0132 16516 Bank 1 probe 1 voltage too high
    P0133 16517 Bank 1 probe 1 signal to slow
    P0134 16518 Bank 1 probe 1 no activity
    P0136 16520 Bank 1 probe 2 electrical fault in circuit
    P0137 16521 Bank 1 probe 2 voltage too low
    P0138 16522 Bank 1 probe 2 voltage too high
    P0139 16523 Bank 1 probe 2 signal too slow
    P0140 16524 Bank 1, probe 1 heating element circuit, short to positive
    P1105 17513 Bank 1, probe 2 heating element circuit short to positive
    P1111 17519 Lambda control Bank 1 system too lean
    P1112 17520 Lambda control Bank 1 system too rich
    P1113 17521 Bank 1, probe 1 internal resistance too high
    P1114 17522 Bank 1, probe 2 internal resistance too high
    P1115 17523 Bank 1, probe 1 heating element circuit short to earth
    P1116 17524 Bank 1, probe 1 heating element circuit, open circuit
    P1117 17525 Bank1, probe 2 heating current circuit short to earth
    P1118 17526 Bank 1, probe 2 heating element circuit open circuit
    P1127 17535 Bank 1, mixture adaption (mult.) system too rich
    P1128 17536 Bank 1, mixture adaption (mult.) system too lean
    P1136 17544 Bank 1, mixture adaption (add.) system too lean
    P1137 17545 Bank 1, mixture adaption (add.) system too rich
    P1149 17557 Lambda control Bank 1 implausible control value
    P1176 17584 Bank 1, Lambda correction after catalyst, control limit reached
    P1198 17606 Bank 1, probe 2 heating element circuit electrical fault
    Knowing which one was stored would help!
  8. Re: help a newbie
    Jan 2009
    thanks for all the help guys!!!ive had enough , scrapping it on monday
  9. Re: help a newbie
    134 Post(s)
    2005 Post(s)
    A little extreme!
  10. Re: help a newbie
    Jan 2009
    im fed up running in circles!at least this way i`ll know the outcome!!!!!!!!!
  1. Newbie
    By Barnie in forum New Member Introductions
    Last Post: 02-03-2008, 02:04 PM
  2. Newbie
    By Fitzy in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 29-02-2008, 02:31 PM
  3. Hello everyone newbie here!
    By mushy2007 in forum Audi A3 - Archive Topics
    Last Post: 27-02-2008, 01:55 AM
  4. Newbie
    By andysmith2901 in forum New Member Introductions
    Last Post: 26-02-2008, 10:01 PM
  5. newbie
    By nickbrice in forum New Member Introductions
    Last Post: 10-02-2008, 08:22 PM
