Thread: VW Golf TDI - Turbo Issue
  1. VW Golf TDI - Turbo Issue
    Jan 2009
    Hello to you all, and i hope you can give sokem advice.
    My Golf Tdi 1.9 have begun to pull on me when i get to a certain speed and also it feels like its behaving like a normal diesel engine and not with the Turbo. I was advised to change the Air Mass Meter, and i have done this but still get the same tugging feel and also it doesnt seem to have the Turbo thrust.
    Can you help?
    Regards
    Graham
  2. Re: VW Golf TDI - Turbo Issue
    Oct 2007
    SHEFFIELD
    There is a boost pressure regulator that fits on the bulkhead this is also a common problem that stops working then if you turn igntion on and off starts working again,but best to get it plugged in rather than guessing cos will end up costing you a fortune
    I dont work here for the pay,or the enjoyment,so why do i work here
  3. Re: VW Golf TDI - Turbo Issue
    Jan 2009
    All,
    I seem to have the same problem with my Mach IV 1.9 TDI. At medium to high revs (bizarrely normally when climbing a hill) the car loses the turbo.
    In the last 2 weeks I have had the airflow meter and the boost pressure sensor replaced - as apparently these are the faults which appeared when the car is hooked up to the Bosch engine management system. However, the problem still exists, and is happening more frequently - but, when the ignition is turn off and back on again, the turbo comes back.
    I have obviously lost confidence the garage being able to diagnose the issue - if anyone has any ideas, you help would be much appreciated!
    Cheers,
    Mark
  4. Re: VW Golf TDI - Turbo Issue
    Southampton, UK.
    Quote Originally Posted by mfinch82 View Post
    ...In the last 2 weeks I have had the airflow meter and the boost pressure sensor replaced - as apparently these are the faults which appeared when the car is hooked up to the Bosch engine management system. However, the problem still exists...
    It could be as simple as a hose that's cracked or has come off. Get your head under the bonnet and do a thorough check.
    2003 VW Golf Est 1.9 TDI 130 (gone but not forgotten after 379,000 miles)
    2006 Audi A3 2.0 TDI Sport 140
    2015 Audi A6 Avant 2.0 TDI ultra 190
  5. Re: VW Golf TDI - Turbo Issue
    Oct 2007
    SHEFFIELD
    These faults normally only happen when driving or break down under load so unless car is connected to diag machine while your driving no they wouldnt show up at all
  1. gti turbo stalling issue
    By stokeVW in forum Chat - Anything with wheels
    Last Post: 28-10-2008, 07:52 PM
  2. Please Help B6 1.9 TDI 130bhp turbo issue
    By ikstece in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-09-2008, 02:38 AM
  3. T5 Inherent Turbo Issue??????
    By norrs2 in forum The Commercial Range
    Last Post: 06-09-2008, 10:57 AM
  4. Audi TT 225 Turbo issue
    By anthony1001wind in forum TT - 8N Forum - 1998 - 2006
    Last Post: 14-05-2008, 08:39 PM
  5. Turbo/ Boost Issue ???
    By naz11 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-07-2007, 12:40 PM
