Thread: OH MY GOD! What a difference a good MAF makes.....
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 50
  1. OH MY GOD! What a difference a good MAF makes.....
    Just thought I'd post a "quick" recommendation that hopefully might help anyone who's Passat (and possibly other VW Tdi) seems as woefully under powered as mine did.
    I was disappointed with my 99 Passat from the moment I bought it, but always put it down to the fact that I still missed my old gas-guzzling Volvo T5
    Since then the performance has just got worse and worse. So much so, that a couple of weeks ago I decided that two years of ever increasing misery was enough and if it couldn't be fixed quickly, easily and cheaply, I'd have to sell it and buy something else.
    I searched this and other forums for advice but most of the threads I found described the "Limp Mode" problem that seems to affect quite of few of these cars. My problem wasn't as specific or intermittent as that. I just had a significant reduction in power across the entire rev range, in all conditions, regardless of fuel type, road speed, time since last service, etc.
    I changed all of the vacuum hoses last weekend and when this had no affect on the problem, I did one last desperate search of the forums and stumbled across a post that mentioned an easy way to check whether the MAF Sensor was functioning correctly.
    The advice was to disconnect the wiring connector from the top of the MAF and take the car for a spin. If it drove the same or better, then the MAF was almost certainly faulty.
    I followed the advice and..... WOW!!!! what a difference!!
    I immediately ordered a replacement (less than £40 inc shipping for an aftermarket equivalent part) which arrived today.
    I fitted it 30 minutes ago and........
    WOW!!!!!!!!!!!!
    Honestly, the car is at least five times better than when I bought it and a thousand times better than it was this time last week.
    So if you think your car is underpowered, please, please, please try disconnecting the MAF, it takes less than 2 minutes, requires no special tools and costs NOTHING!!!!! and it might just save you a whole lot of time and money trying other more complex diagnostics methods.
    Sorry to go on, but if this mammoth post helps just one person achieve the same result as i have tonight, it'll be worth the hour that its taken me to write it
    2 0 0
  2. Re: OH MY GOD! What a difference a good MAF makes.....
    Aug 2007
    Do you mean MAF or MAP sensor? They are different.
  3. Re: OH MY GOD! What a difference a good MAF makes.....
    Definitely MAF (Mass Air Flow)
    One other point I forgot to mention is that a duff MAF Sensor won't necessarily throw up any Fault codes in the ECU, so VAGCOM won't find it and it could easily be overlooked by mechanics.
  4. Re: OH MY GOD! What a difference a good MAF makes.....
    133 Post(s)
    1987 Post(s)
    Do not disconnect the AMM (MAF if you must call it that) unless you can clear the fault code that it will generate doing so. Also, only buy the AMM genuine from your dealer, aftermarket ones last about six months.
  5. Re: OH MY GOD! What a difference a good MAF makes.....
    Dec 2006
    Manchester
    Am i right in saying;
    AMM - Air Mass Meter
    MAF - Mass Air Flow Meter
    VAG do not recogneise the term MAF, So AMM is the correct description.
    Nick
    1.9 tdi PD 100 Bora
    110cc pitbike, 4 speed semi-auto
    110cc Off road buggy, 4 speed semi-auto
  6. Re: OH MY GOD! What a difference a good MAF makes.....
    133 Post(s)
    1987 Post(s)
    Even VAG can’t make up their minds. On the parts system it is an Air Volume Meter and on the workshop system, as Air Mass Meter.
  7. Re: OH MY GOD! What a difference a good MAF makes.....
    will this part make the car chugg slightly at around 30 mph if as not enough revs are being applied ?
  8. Re: OH MY GOD! What a difference a good MAF makes.....
    I guess so, but don't quote me on that
    My car exhibited power loss at all revs / speeds (can't say what it would have been like at 70+ mph cos I could never get there)
    Ultimately the MAF, AMM or AVM (3 names 1 part ) tells the ECU how much air is flowing through to the Intake Manifold. This figure is then used in the calculations that decide how much fuel, boost, etc. is required.
    Bad AMM = Wrong number to ECU = Engine not performing at optimal parameters
    I take Crasher's earlier point about the fault code that will be generated, but would say that the code in itself will not CAUSE any problems and can be easily cleared by anyone with access to VAGCOM or similar, or when the car next goes in for a service (just remember to tell the mechanic that you know why the code is there and its not something that they necessarily need to worry about unless it comes back AFTER they have cleared it)
  9. Re: OH MY GOD! What a difference a good MAF makes.....
    Stafford, Midlands
    mine had a faulty avm/amm when i bought it, didnt realise till i got it serviced and they told me, i didnt know any different, afterwards it was a very different car to drive, then it still had a faulty fuel temp sensor, had to wait for parts and socket to open pump, but it was brilliant after i'd done it, did coinside with getting the car chipped though, so was a million times better after that too!! tiny things of these cars make huge differences in performance
    Subaru broken, sold, Silver Seat Leon Cupra 180 '02' no cupra badge?
  10. Re: OH MY GOD! What a difference a good MAF makes.....
    Aug 2007
    Where exactly is the MAF? I have a 2001 Passat TDI 130. Is it somewhere near the airbox/filter?
  1. 3.6-litre V6, 300 Ps: New Passat R36 Makes Uk Debut
    Last Post: 28-04-2008, 08:21 PM
  2. Dump Valve Makes Noise In Neutral
    By turner in forum Golf MK4 - 1999 - 2004
    Last Post: 12-04-2008, 03:30 PM
  3. Who makes vw suspension arms?
    By jemthetaxi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-03-2008, 12:39 AM
  4. What makes you smell? (a prequel to 'do you pass wind?')
    Last Post: 08-05-2007, 01:19 PM
  5. Makes of tyres
    By Brianm in forum Archive posts
    Last Post: 23-12-2006, 01:33 PM
