Thread: Address 21 errors within 46 Central Convenience
  1. Address 21 errors within 46 Central Convenience
    Jul 2007
    Cheshire, or my A6
    Guys, girls
    Was assisting a fellow forum member long into the night. We were trying to match his remote keys to the second hand CCU he had fitted, as the car suffered from water ingress.
    In the memory positions, the code is "1100" which shows two keys assigned to memory. However, he has only one key, and when the value is changed (test and save) channel 21 in address 46 central convenience reports an error. It does this regardless of what memory position you assign the key to.
    There are no fault codes regarding the CCU or key programming at all.
    The car is a Y reg Audi A4 (B6) 2.0.
    I'm running fully registered 409.1 VAG-COM.
    Help is hugely appreciated!
    Paul
  2. Re: Address 21 errors within 46 Central Convenience
    May 2007
    knee deep in clunge
    14 Post(s)
    try 10 channel 0 delete learned values first you must delete the existing remotes adapted to the control unit
    check the control unit part number
  3. Re: Address 21 errors within 46 Central Convenience
    Jul 2007
    Cheshire, or my A6
    Quote Originally Posted by a8 tech View Post
    Sorry I've not replied for ages.
    Unfortunately I can't even delete the memory positions, I hit zero and test and save but then the error occurs, sounds to me like it just won't re-code.
    I'll PM the forum member for the code, its not my car so I can't just get that info.
    Its strange, in trying to help the other member, I tested his key by splitting it and adding my remote section to his blade. That ruined R/C/L on my car, and now I change the value from 0 to 1 but they return to zero immediately. Thankfully we re-coded them via a key in door method. The memory positions are correct in my car, 1100.
    Paul
  4. Re: Address 21 errors within 46 Central Convenience
    May 2007
    knee deep in clunge
    14 Post(s)
    no problem Paul,if you need further help pm me as im not around as much these days
  5. Re: Address 21 errors within 46 Central Convenience
    Jul 2007
    Cheshire, or my A6
    Will do, thanks very much.
    I was hoping one of the Ross-Tech guys might know something, as to why it would throw an error.
    Paul
  1. Official Audi AG complaint address?
    By a4_jim in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-08-2008, 01:40 PM
  2. Convenience system central control
    By ukheman in forum Golf MK5 - 2004 - 2009
    Last Post: 27-12-2007, 06:37 PM
