Thread: Air Mass Meter
Results 1 to 10 of 14
  1. Air Mass Meter
    Mar 2007
    Staffs
    I know you guys have probably had this question a million times before, but please excuse this as this is only my second post on here.
    I have a 1996 1.9 TDI 110 BHP A4 with 155,000 miles on the clock, FSH, and drives and looks like showroom condition. (Very lucky to have the pleasure of buying one in this condition).
    It has just passed its MOT yesterday, only thing that needed doing was a new wiper blade.
    Anyway, when i accelerate away the turbo kicks in quite smooth, i can go through the gears to 50-60 mph with no troubles, then all of a sudden the power just goes, I pressume the turbo is kicking out, and the only way i can get the turbo working again is if i pull over, stop the car, then restart it again. Clearing the memory on the ECU i pressume.
    Any way ive had the boost control box replaced(I think thats what its called), and when i brought the car, they told me they had replaced the air mass meter, but i had my doubts from day one.
    Would anyone say this sounds like an air mass meter problem, and also could anyone recommend where i can obtain a reconditioned unit from for a reasonable price?
    Many Thanks (Sorry for boring you gys again)
    Andy.
    Feb 2007
    Leicester
    Hi. I am no expert but my 115TDi (2001) was significantly dowm on power when i bought it a few weeks ago. I had the fault codes read and that didn't show anything. It turned out to be the airflow meter. problem solved. Have you had a diagnostic check done? That would be the first point of call i think. A good independent garage should have the right equipment to do this or you could pay a lot more and get an Audi dealer to do it.
    Some other people on this forum know a lot more about these sort of things and if you ask nicely they may give you some more detailed advice. Good luck.
    Oct 2005
    Lutterworth
    Quote Originally Posted by andyd118 View Post
    This is what is called "limp mode".
    Probably caused by an over-boost condition.
    You need to log the sensors when doing an acceleration run to do a proper analysis otherwise you can just throw parts at it.......
    Find someone local with a VAGCOM who can help you out.
    Do a search on any terms used here that are not familiar to you...
    Passat Estate 2002 PD130
    Passat 1.8SE 1998
    Andy.
    i have a audi A4 1.9TDI R-Regs and it dose the same as yours if i go over 2500 RPM the turbo cuts out i have to turn the engine off and restart it then ok up too 2500rpm, i have put a new air flow meter on cost me £100 but did not fix it and the part was non-returnable
    Oct 2005
    Lutterworth
    Quote Originally Posted by Mrkray View Post
    It's probably going into limp mode because of an overboost condition.
    This is unlikely to be caused by the MAF but by the boost control system.
    Like I said earlier, invest £70 (1hour's garage labour) to buy a registered VAGCOM and cable and diagnose it properly, otherwise your p*****g in the wind.
    Passat 1.8SE 1998
    Feb 2007
    Could be the maf sensor BUT spare 5 mins and try this.
    i think it could be a burst pipe, happened to me about a fortnight ago. Look at your intercooler, follow the pipe thats coming out of it and going into the engine inlet manifold, this plastic pipe is connected to the engine manifold near the turbo via the aid of a rubber bit with 2 clamps on. Even though it might look ok from the top just trust me on this, take the clamps off and you will find that the pipe is cracked from the bottom.
    Replace it and hopefully anjoy your car.
    My two cents
    norn iron
    the wifes car has been doing this for some time.ive spent weeks,checking hoses,valves,cleaning egr,replaceing maf the list goes on but to no avail.left it into my local indy vw man,hooked it up,overboost and something else ,think it was (piston alignment or something)any way,tells me its turbo related vanes sticking got it booked in on friday turbo off,stripped and cleaned.picked it up on friday afternoon for her,totally different car.goes almost as quick as mine well not really but wot a difference.charged me £50, as i no him,you can actually hear a proper turbo sound now rather than a funny whistle sound
    Oct 2005
    Lutterworth
    Make sure you tell her to give it a bit of welly every now and again to cycle the vanes.
    Passat 1.8SE 1998
    norn iron
    Quote Originally Posted by Lex Luthor View Post
    no lex thats my job ,ive already told her this on many occasion,u no wot women r like,in one ear out the other
    Mar 2007
    Hi wonder if anyone can help on here, i've got an A3 1.9TDi (2001) and recently it's lost it's punch when you put your foot down it just doesn't take off like it used to.
    I've been told it could be the plugs that need changing, someone else mentioned that it could be the turbo thats gone, could this be the air flow meter ?
    Thanks in advance...
  1. Air Mass Meter
    By Joey74 in forum Beetle 2000-
    Last Post: 31-08-2010, 02:16 PM
  2. golf 1.4 air mass meter
    By Rusty36 in forum Golf MK4 - 1999 - 2004
    Last Post: 28-12-2007, 02:32 PM
  3. Faulty Air Mass Meter
    By Joey74 in forum Archive posts
    Last Post: 28-04-2007, 11:31 AM
  4. Air Mass Meter
    By andyd118 in forum Audi A4 - Archive Topics
    Last Post: 20-03-2007, 04:55 PM
  5. Air Mass meter question
    By skymaster in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 26-01-2007, 09:01 PM
