Just thought I would share my solution to my rear washer jet stopping working following a recent cold snap.
I presumed the connections had popped somewhere due to ice, as people mention on here. I first removed the boot panel (two screws, one behind safety traingle, the other in the handle) then a bit of brute force to pull the panel off (several strong clips). I found that the pipe onto the back of the wiper was fine, I took it off and tried squirting, nothing.
After reading the forum I then headed for the front passenger foot well, carpet felt dry, but I took the plastic panel off the side and pulled the carpet back. I found the pipe amongst the wires on the left hand side, I think it may have actually been still joined together but it unclipped as I pulled it out. There was a little bit of dampness in the footwell however, and in the sump where the convinience unit is, but I dont think its washer fluid, so looks like I need to check the drains under the battery asap.
After reconnecting the footwell pipe washers still were not working, so I then headed to the back of the car, and found the pipe in the cubby hole in the left of the boot, I think it may be where the multichanger would live if I had one. The pipe was disconnected here. I pulled out the polystyrene base from the cubby hole and found the area fully of about 3 inches of washer fluid. There is a gromet in here so I simply reached down and pulled the gromet out to drain the area, then replaced.
Washers are now working great, just need to dry everything out.
Hope this helps someone, someday.
Paul
