Thread: Sharan Bulb Change
  1. Sharan Bulb Change
    tibs17czku Guest
    Hi. I am new to this forum,
    I am having problems replacing my headlight bulbs on a 03 plate sharan.
    I know that under the wheel arch there is a panel for accessing the lights but i dont know how to open it. Please help.
  2. Re: Sharan Bulb Change
    May 2008
    wirral
    the headlights and side lights are done from above the car bonnet open..on top of the lights there is a black plastic cover..lift of look behind the back of the light you will see plastic cover plate..on the top of it there is a metal clip..flip it of the plastic cover should lift and come of...look at the back of light if you can see you will have a metal clip & power plug connected..you probably know how to do the rest then the reverse...the galaxy has to be done from through the wheel arch the sharan just indicators..hope this helps...ps battery side bit of a pain..
  3. Question Re: Sharan Bulb Change
    tibs17czku Guest
    In the manual it says the side lights and the indicator lights can only be accessed through the wheel arch. when i put my hand up into it there is one long sort of lever for the indicator bulb and if you put hand slightly more up the is a very short and hard to reach lever for the side bulb. But i can just about touch it never mind twist it.
    It's too complicated.
    How do other people do it?
  4. Re: Sharan Bulb Change
    May 2008
    wirral
    Quote Originally Posted by tibs17czku View Post
    i can only tell you what i know i have an o3 plate sharan i done my drivers side last month done it through the bonnet thats alls i can say...what i do know is when it comes to the indicator ill be goin through the wheel arch..
  5. Re: Sharan Bulb Change
    Mar 2009
    tibs17
    I have done this twice on my sharan in both sides.
    The passenger one is easier and more reachable but the drivers side is very tricky unitl I discorvered an easy way to do it!!
    I have a larger flat headed screwdriver which with the bonnet open I can slide the screwdriver into the sidelight holder and twist anti-clockwise this will open the light and carefully take it out. To put in back in again after the bulb is replaced just place in on the screwdriver and slot it back into place and twist clockwise!!
    That should do the trick, let me know how you get on?
  6. Talking Re: Sharan Bulb Change
    tibs17czku Guest
    Thanks a lot.
    I took my car down to my local garage and it took them 5 minutes to replace both bulbs without any sweat. He said we have many German cars coming in with this problem.
    Well thanks again.
  1. Changing sidelight bulb on 04 sharan
    By James H in forum Touran - Sharan - Caravelle
    Last Post: 16-01-2016, 06:26 PM
  2. Bulb Change
    By WelshBoa in forum Touran - Sharan - Caravelle
    Last Post: 09-02-2009, 12:24 PM
  3. Bulb Change?
    By faruq in forum Golf MK5 - 2004 - 2009
    Last Post: 23-09-2008, 08:36 PM
  4. sharan 04 bulb light warning
    By danger mouse in forum Touran - Sharan - Caravelle
    Last Post: 21-11-2007, 04:57 PM
  5. How do you change a bulb?
    By barney2 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 18-10-2007, 07:22 AM
