Thread: ECU Coding
  1. ECU Coding
    Jan 2009
    Hi All,
    I need an ECU to replace a water damaged one for a friend.
    The problem is i can not get the exact same one locally.
    I was wondering if the following would work and how to get them coded?
    The engine is AEH
    The original is: Siemens 06A 906 019 CN, 5WP4439
    But i can only get: 06A 906 019 BQ, 5WP4448 or 5WP4459
    Would it work??
    Thank you
  2. Re: ECU Coding
    Sep 2007
    hi, what make model is it from? check vagcat for compatability I just swapped a 4B0 920 980 G for a 4B0 920 981 BX with a d11 instead of d5 on software and worked fine after getting SKC out with vag commander.
  3. Re: ECU Coding
    Sep 2009
    Varna
    Quote Originally Posted by toniz View Post
    Hi All,
    The engine is AEH
    Would it work??
    Thank you
    Do you have internal pistures of this ECU: 06A 906 019 CN ?
    If YES, may I ask you to share them?
    I will be very grateful !
    Thank you.
  1. coding a key
    By jcb in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-11-2008, 08:56 PM
  2. Vag-Com coding
    By christoff1604 in forum Touran - Sharan - Caravelle
    Last Post: 10-11-2008, 02:21 AM
  3. Help with coding in my sat nav plus
    By a6rob in forum VCDS - General Questions
    Last Post: 06-07-2008, 01:33 PM
  4. Fob coding
    By sidewinder306 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-09-2007, 07:03 PM
  5. coding for air bag ecu
    By r9mey in forum Beetle 2000-
    Last Post: 08-06-2007, 07:40 PM
