Thread: Converting manual to auto
  1. Converting manual to auto
    May 2008
    Does anybody know if its a possible to convert a Mk3 Golf GTi 2.0 8v from manual to auto and if so from which car will the auto box have to come from - 1.8 or 2.0.
    Any advice would be appriciated.
  2. Re: Converting manual to auto
    134 Post(s)
    2001 Post(s)
    Yes it is possible and some Vento’s came with the 2 litre engine and auto box. Which year and engine code?
  3. Re: Converting manual to auto
    May 2008
    Not sure of engine code although engine number is ADY033761. Year is 1995.
  4. Re: Converting manual to auto
    134 Post(s)
    2001 Post(s)
    The engine code is ADY.
    You need a CFH, CNK, CNP, CLK, DKS, DLZ, or DNS code box plus all its mounting parts.
    Engine wiring harness (the original only requires some very small changes so it depends on which you are most comfortable with).
    Gearbox wiring harness and ECU.
    Engine compartment wiring harness
    Interior wiring harness
    The engine ECU can be very quickly recoded for auto box operation otherwise you will need the engine ECU, immobiliser and key chip (difficult to extract) from the donor vehicle.
    Driveshafts.
    Gear shift system and consul trim
    A small power steering clip to the body
    Engine backing plate
    Flex plate and torque converter plus washers and new special flex plate bolts
    Water transfer pipe and trans fluid cooler hoses
    Head side water outlet housing
    Radiator
    Front transaxle mount
    Rear engine mount and block bracket
    Brake pedal and some associated parts
    Steering column lock (you will need to swap over your ignition barrel which means drilling both lock housings to extract the barrels)
    Dash clock set (so the mileage will be wrong)
    Fit a starter inhibit relay (this just plugs in)
    And I am bound to have missed a few things, the above is just a quick run through. The only sensible way to do this would be to find a 2 Litre Vento from 95 to 98 with the ADY or AGG engine and swap everything over as required.
  5. Re: Converting manual to auto
    Dec 2008
    Sell it and by an auto!
  6. Re: Converting manual to auto
    May 2008
    Cheers for the advice. Think I'll buy the auto!
  7. Re: Converting manual to auto
    134 Post(s)
    2001 Post(s)
    Well I would not have thrown my usual “never build a car you can buy” at you as you can’t buy an auto Golf 3 GTI. There were a few Golf 3 VR6 auto’s and if you can stomach the fuel consumption and higher running costs, these do make nice cruising cars that are easy to live with. I have worked on a few and I rather like them when I know I really shouldn’t.
  1. Question Converting A Manual window to electric window
    By JTaylor2005 in forum Golf MK3 - 1993 - 1999
    Last Post: 20-11-2008, 05:51 PM
  2. Please Help Caravelle VR6 Auto - can it be converted to manual or replaced with Sharan auto/manual
    By flying fish in forum Touran - Sharan - Caravelle
    Last Post: 08-11-2008, 11:56 PM
  3. auto to manual convertion
    By herkie in forum Polo - Derby - Lupo - Fox
    Last Post: 01-10-2008, 08:51 AM
  4. Converting an 1998 AUDI A4 1.8T SPORT AUTO to manual?
    By Lennard in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-08-2008, 09:26 AM
  5. Tdi Auto Or Manual ?
    By ajc in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-12-2007, 12:07 PM
