Thread: Leaky tailgate
  1. Leaky tailgate
    Jul 2007
    Hi Chaps,
    I have an A6 Avant (1999) that is always wet (when it rains), at the bottom of the inner tailgate. I had a loose hinge bolt during the Summer but I tightened the bolt and aligned the door gap.
    Anyone had any similar problems, could it be a worn door seal or maybe the roof arial seal perished??
    Thanks in advance for any help.
  2. Re: Leaky tailgate
    Hi Water ingress,can sometimes be hard to locate.You can rest assured it is not the aerial otherwise the headliner would be soaking.First check the drain holes at the bottom of the tailgate.While sitting inside the boot,get someone to hose the tailgate.Starting at the bottom and gradually move the hose upwards,and see if you can find out in which position the hose is in,when the water starts to enter the vehicle,number plate,rear wiper,rear window,and the rubber grummets on each side on top of the tailgate, are some places you can look out for.
  3. Re: Leaky tailgate
    I had a similar problem and found a leaking washer pipe - only used to clean the rear screen when it was raining!
  4. Re: Leaky tailgate
    Jul 2007
    Hi Kenney,
    Where are the drain holes located?
    Mickyboy22
  5. Re: Leaky tailgate
    You could smell it. if it had of been washer fluid.The drain holes are on the seam of the inner and outer plating along the bottom of the tailgate.
  6. Re: Leaky tailgate
    Jul 2007
    Thanks for your advice, I will look at the problem on Saturday when there is some daylight.
    Mickyboy.
  1. Leaky radiator
    By limawhiskey in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 03-06-2008, 07:26 PM
  2. Leaky Mirror
    By dannyl321 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-12-2007, 11:52 PM
  3. Leaky S4 gearbox
    By HANK in forum Archive posts
    Last Post: 08-11-2007, 12:01 PM
  4. Leaky Roof?
    By treb0r in forum 80 - 90
    Last Post: 28-10-2007, 05:35 PM
  5. Leaky
    By jp01 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 01-03-2007, 03:41 PM
