Thread: 1998 Mk4 Golf Electical Gremlins?
  1. Unhappy 1998 Mk4 Golf Electical Gremlins?
    Jan 2009
    Car: 1998 GTi 1.8T
    God where do i start . . . Right driving along hunky dorey and all of a sudden Chris Moyles went dead on the Radio, the head and dashboard lights went dim, also the ABS and Airbag warnings illuminated . . . . after about 30 secs every thing comes back online and the car is running well! so i though oh well just a little bug as its happened once before about a week earlier! then today the same thing happened, but this was outside the house, so i turned the ignition off, and tried to start the car again, the car then failed to start as if there was very little juice . . . . 10 mins later it starts and runs fine. Tha battery is almost new just wondering what the hell is going on? Im sure the battery is fine but after everything comes back online the car seems like better before . . . . Hope you guys can help!
  2. Re: 1998 Mk4 Golf Electical Gremlins?
    Pembrokeshire
    22 Post(s)
    youve probably got a corroded earth connection. i think theres an earth point under the battery that can suffer. also check your battery terminals, and connections to the starter motor and engine earth point.
  3. Re: 1998 Mk4 Golf Electical Gremlins?
    meathead Guest
    Definatley sounds like a bad earth!
  4. Re: 1998 Mk4 Golf Electical Gremlins?
    Jan 2009
    Right i removed the battery and its shelf, cleaned both battery terminals, sanded and cleaned the main Engine to Battery earth, removed the Altinater lead and cleaned that as well as 3 other chassis earths i found under the battery tray! started her up and she seems sweet, will give it a week and report back on here . . . . Thanks Guys!
  1. Electical Failure
    By tmh970 in forum Golf MK2 - 1984 - 1992
    Last Post: 09-07-2008, 09:41 AM
  2. Electrical gremlins
    By brighton123 in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 09-04-2008, 11:06 PM
  3. Gremlins in my electrics again. Mk3 golf
    By kojack3175 in forum Golf MK3 - 1993 - 1999
    Last Post: 15-11-2007, 12:44 PM
  4. Electical and Relay Questions
    By doodbrie in forum 80 - 90
    Last Post: 08-11-2007, 11:08 PM
  5. Golf MK5 Electrical Gremlins
    By kryten2001 in forum Golf MK5 - 2004 - 2009
    Last Post: 16-07-2007, 03:12 AM
