Thread: Fault code 17544
  1. Fault code 17544
    Jun 2008
    Hello.
    I keep getting this fault code after about 100miles :
    17544 : Fuel Trim: (Add): System too lean.
    I know this is to do with the engine idle. I've searched the forum and seen about the possibility of those dodgy braided vac hose's. I've also checked the crankcase ventaltion pipe, but couldn't see a problem with that.
    I've posted the pic below. I've changed some of the vac lines. The green lines are the vac pipes changed and the red line is a braided hose yet to be done.
    Dont know if the pic can be seen above, but its the hose that runs from under the inlet manifold, across the front of the engine towards the airbox, and down the side to the bottom. Anybody know an easy way of getting to it? And will it help cure the above code.
    Many thanks in advance!
    (Engine is 1.8T AWT.)
  2. Re: Fault code 17544
    Jun 2008
    Anybody know how to post a pic on here!! Tried using photobucket, i cant be doing it right!!
  3. Re: Fault code 17544
    Gwent
    If you're hosting it ok on photobucket, just copy and paste the 'Image address' directly into your post. I think it is the bottom one of their 4 options - starts and ends (IMG)
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  1. ABS Fault, have fault code readout....
    By nemeth782 in forum Golf MK4 - 1999 - 2004
    Last Post: 30-08-2008, 12:15 PM
  2. Fault Code
    By pugville in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 01-07-2008, 12:38 PM
  3. I was going to buy a vr6 then I saw this fault code.......
    By londoncalling in forum Golf MK3 - 1993 - 1999
    Last Post: 25-06-2008, 02:58 PM
  4. Replies: 0
    Last Post: 15-01-2008, 01:07 AM
  5. fault code 17544
    By Lee Toone in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-09-2007, 01:14 PM
