Thread: High milage scirocco
  1. Smile High milage scirocco
    Nov 2005
    I've recently bought a 1990 GT2, with full service history, from one genuine, middle aged lady owner. However it does have about 200k on the clock. Does anyone know when the engines are expected to give up? also when they do roughly how much for a new engine and fitment?
    Nov 2005
    200k is quite high! But as long as it's been well serviced then all should be well. I'd be more concerned about other bits like fuel lines, suspension bushes, brake lines etc.
    The engines are quite plentiful on ebay type places and breakers yards as they were fitted to several vw's of the period, you can also drop in other similar engines from the VAG group.
    A good garage will be able to change an engine in 1-2 days as they are fairly straight forward, so find out your local garages hourly rate on such a job.
    Brunty
    Nov 2005
    Is it fairly costly to get a replacement engine fitted. I could easily source the engine, it's just fitting it that's the problem. I've fitted a VW transporter with a 1640cc air cooled engine. But I recon it's a hell of a lot simpler than a scirocco.
    If anyone's had an engine fitted, and they know how much it costs in labour then it would be helpful. Cheers.
    Nov 2005
    Quote Originally Posted by TomLaw
    Well I changed one recently and can verify that it is not a difficult job, one that a diy'er can do for sure.
    Assuming a garage charges say £25 per hour you will be looking at £200 - £400 for the swap, you'd want to ask if they'd dispose of the old engine for you though.
    Brunty
    Nov 2005
    I've seen a few engines go recently for the region of £100 for an 8v and a bit more for 16v, so not too bad, and say about £200 to have a garage fit it. However the way Sciroccos are in the market now you can pick one up a full car for not alot more than buying a replacement engine and having a garage fit it.
    Unless the cars in absolute mint condition its probably not worth the hassle, but if you do fany it then I'd go for a 16v conversion to make it worth while
  1. scirocco tuning
    By salem186 in forum Scirocco - Corrado
    Last Post: 27-05-2008, 01:25 AM
  2. New guy milage quiery re:TDI's, advice needed!!!
    By teccyjim in forum New Member Introductions
    Last Post: 04-05-2007, 12:35 AM
  3. WHAT DOES 'l N l' ON MILAGE LCD MEAN
    By JOSEPHSAUDI in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-02-2007, 03:34 PM
  4. Scirocco
    By auiron in forum Scirocco - Corrado
    Last Post: 31-12-2006, 03:29 AM
  5. High Milage Passat 'a good buy' ?
    By stevenm in forum Passat - Archive Topics
    Last Post: 09-06-2006, 12:56 PM
