Thread: Memoscan VAG 5053 & New Beetle fault
  1. Exclamation Memoscan VAG 5053 & New Beetle fault
    Jan 2009
    Middlesbrough
    2004 New Beetle 1400cc manual petrol 28,000 miles mil showing
    Hi, my daughters Beetle has the following re occurring fault codes
    P0134 oxygen sensor bank one sensor one (no activity) this is the sensor before the cat.
    P0139,oxygen sensor Bank one sensor two (response too slow) this is the sensor after the cat.
    P1198 oxygen Bank one sensor two (electrical malfunction).
    After clearing the fault codes down they re appear after around 80 miles of driving. It used to go a couple of hundred miles before the mil came on but now comes on sooner.
    The car recently passed an mot test and the car drives normally.
    Recently another fault code has shown up
    P0571 Brake switch (F) implausible signal.
    Given that the car has only done 28,000 miles and runs ok can anyone shed any light on what may be causing the problems.
    Thanks for any help. The brake switch was the culprit and was renewed, the lambda sensor before the cat was also faulty and renewed and the car runs normally. Sorry about the long delay in responding but thought it might help someone with the same symptoms. Thanks again to Crasher.
  2. Re: Memoscan VAG 5053 & New Beetle fault
    131 Post(s)
    1976 Post(s)
    The brake light switch is clear cut, it needs a new one. The other issues may be that one or both lambda sensors are faulty or that a problem in the engine has caused failure of these sensors. Some time spent studying measuring blocks would be needed.
  3. Smile Re: Memoscan VAG 5053 & New Beetle fault
    Jan 2009
    Middlesbrough
    Thanks for pointing me in the right direction Crasher. I will do some checks and post the results.
  1. VAG 5053 Handheld scanner
    By vr6280 in forum VCDS - General Questions
    Last Post: 09-09-2009, 07:47 PM
  2. VAG 5053 diagnostic tool
    By AJC2008 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-09-2009, 10:09 PM
  3. VW/Audi CAN BUS VAG 5053
    By skodaman in forum Octavia
    Last Post: 17-08-2008, 05:33 PM
  4. memo scan vag - 5053
    By squar9 in forum VCDS - General Questions
    Last Post: 01-07-2008, 12:33 AM
  5. 2001 beetle fault codes
    By gammo24 in forum Beetle 2000-
    Last Post: 10-02-2008, 03:48 PM
