Thread: rough running, power loss
Results 1 to 10 of 18
  1. rough running, power loss
    Mar 2007
    west midlands
    VW transporter running rough and with power loss, seems to happen when engine under load. allow to tickover for 5 minutes and problem cured short term.
    Any idea's anyody?
    Cheers,
    Baloo.
  2. Re: rough running, power loss
    What model and what engine are you refering to ?? A bit more detail needed firstly...!!!!
  3. Re: rough running, power loss
    Mar 2007
    west midlands
    Thanks for your reply, the engine is the 2.5tdi AJT 88bhp 2003.
  4. Re: rough running, power loss
    Cornwall
    That's an odd one baloo. The only thing I can think of that changes after 5 mins or so idling is the EGR valve. It can be open at idle but closes after a while (I think that's the right way round!)
    Also, it should also be closed at full throttle but perhaps yours is open causing the problem. It might show a fault code if you can find someone with vag-com and you can check what it is doing with vag-com too. They can get quite sludged up after a while.
  5. Re: rough running, power loss
    Aug 2008
    i hope you are not about to have the problem i had. was finally diagnosed as faulty injector pump which was replaxced with new, and then required new turbo as original was coked up due to injector pump fault.
  6. Re: rough running, power loss
    My understanding of the EGR is much the same, I believe it should only be open at tickover and when at cruising revs, it only closes I believe when you are accellerating.
  7. Smile Re: rough running, power loss
    Cornwall
    The change in the EGR state is the hopeful thing here. I only know about the 5 min idling thing from the Erwin manual I had when I had my T4. I have a 174 T5 now :-) Fitted the modified water pump today, strange job for a water pump but not too bad!
  8. Re: rough running, power loss
    Mar 2007
    west midlands
    T5 174 would be nice, maybe one day
    Van has now been tested with the EGR blanked off and the problem is still the same VW replaced the EGR stating this was the cause (another thread on here) a lot of people are saying air in fuel, but VW insist that the fueling is correct I have looked at the return pipe, well i think it is the return, for air bubbles and all seems well with no air bubbles.
    Doesn't make sense that if the van is allowed to tickover then it runs fine for a short while, if the rough running returns then allow to tickover for 5 minutes and problem cured again, This applies to when first started in the morning too, ticks over a little lumpy, give it a few revs and allow to tickover and runs fine........... if you keep the revs down. If making the van work harder (up Hill) then the rough running returns instantly
  9. Re: rough running, power loss
    Cornwall
    I suppose the cat or exhaust partially blocked is another possibility...
  10. Re: rough running, power loss
    Mar 2007
    west midlands
    Cat and exhaust has been replaced by VW
  1. Please Help 1.8 Petrol loss of power, poor running.
    By cherrymetal in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-08-2008, 03:12 PM
  2. 1.8 8V running rough.
    By sportline in forum Golf MK1 - 1974 -1984
    Last Post: 28-04-2008, 10:05 PM
  3. Mk3 GTI 8v - Rough running
    By scorchi0 in forum Golf MK3 - 1993 - 1999
    Last Post: 31-12-2007, 02:25 PM
  4. Rough running
    By andrew.butler57 in forum Golf MK3 - 1993 - 1999
    Last Post: 22-11-2007, 04:08 PM
  5. 1.8t a3 running rough poor idle no power???
    By djglovehead in forum Audi A3 - Archive Topics
    Last Post: 10-04-2007, 06:33 PM
