Thread: Continually blowing rear brake light bulbs
  1. Continually blowing rear brake light bulbs
    daled Guest
    My July2002 A4 1.9TDI 130 SE is continually blowing rear brake light bulbs (more offside than nearside)
    Can anyone suggest a reason for or solution to this problem.
    I think it might be a loose or exposed connection on the clusters but not sure how to check. I know how to get the clusters out but not what to look for as the root of the problem.
    Thanks in advance of any assistance
  2. Re: Continually blowing rear brake light bulbs
    131 Post(s)
    1973 Post(s)
    A loose connection will not make the bulb blow. Which make of bulbs are you using?
  3. Re: Continually blowing rear brake light bulbs
    Southern County Softy
    20 Post(s)
    Cheap ones maybe.........
    A4 2.5 tdi QS (mapped)
  4. Re: Continually blowing rear brake light bulbs
    daled Guest
    I usually get them from Halfords. I may also check all the connections anyway and next time it happens check the bulb more thoroughly to ensure it has actually blown
    Isthe best place to get the bulbs an Audi main dealer
  5. Lightbulb Re: Continually blowing rear brake light bulbs
    Jun 2008
    Wrexham Wales
    you definetly getting correct bulbs cos there are a few type of twin filament bulbs available most common types are off set pins and in line pins just a thought cheers
  1. Please Help Brake Light Failure Indicator shows brake bulb fault but bulbs are ok
    By IrlA4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-02-2012, 12:56 AM
  2. Question Changing third brake light bulbs??
    By nigel_07 in forum Audi A3 - Archive Topics
    Last Post: 07-07-2008, 06:52 PM
  3. Passat rear light bulbs
    By WesleyP in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-05-2008, 07:10 PM
  4. 3rd brake light bulbs - replaceable?
    By a4tdidriver in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-04-2008, 07:44 PM
  5. 3rd Brake Light Bulbs
    By audinut in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 29-01-2008, 10:33 PM
