Thread: Leaky windscreen washer container? Polo 1.2 E
  1. Leaky windscreen washer container? Polo 1.2 E
    Dec 2008
    Bit of a wierd one this, but I recently took my 02 Polo 1.2 E 65BHP in for a standard service at Kwik-Fit (I know, I know) and ever since, it has had several problems.
    1. Often difficult to start (well, takes a couple of goes - doesn't seem to make much difference whether engine is hot or cold
    2. Intermittent exhaust emissions light
    3. When I fill the windscreen wash 'tube' it is empty after a day or so, even without using the windscreen washer.
    I am just putting up with the first two, but the third seems very wierd. Does anything else use the windscreen wash?
  2. Re: Leaky windscreen washer container? Polo 1.2 E
    Jan 2009
    Reading
    sounds to me like you should either take it back to them, or re trace what they did during the service.
    Did they do timing belts during the standard service or just fluids and filters? If they did belts then possibly not quite got the timing correct, which is a worry. May cause the poor starting. Or maybe they put the fuel filters on backwards(they have a flow direction usually) or something dim.
    The screen wash bottle has a pipe off somewhere, fill it up and look under the car, should be able to see where the water escapes. Or less likely, split in the bottle maybe.
  1. Question Windscreen Washer Pipe
    By John S in forum Jetta MK3 - 2005 - 2013
    Last Post: 29-04-2009, 03:25 PM
  2. Windscreen washer spray adjustment
    By clarkejw in forum Golf MK5 - 2004 - 2009
    Last Post: 04-12-2008, 09:23 PM
  3. Question Rear windscreen washer
    By cornishboy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-07-2008, 08:57 PM
  4. Windscreen washer nozzles
    By broket in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 15-05-2008, 08:38 AM
  5. Heated windscreen washer jets?
    By Zub in forum Passat - Archive Topics
    Last Post: 02-03-2007, 04:55 PM
