Thread: Interference from Heated window switch
  1. Interference from Heated window switch
    Mar 2008
    Staffordshire
    Heres a strange one.
    I only started noticing it a few months ago, but whenever I press the button to operate the rear window heater I cannot listen to any radio stations other than radio 1,2,34 etc.
    Any other station and all i can here is interference.
    Has anyone else ever experienced this? I can only assume that the wires leading to the switch must run close to the radio receiver and the current within the wires is causing a little magnetic field thats disrupting the radio.
    Vw Bora 2005 130TDI HIghline - P-Torque remap - Gone but not forgotten.
    2003 BMW Z4 3.0i - Regretfully gone
    Current car - 2008 Z4 Coupe
  2. Re: Interference from Heated window switch
    Apr 2007
    I've had this happen before.
    If there are any breaks in the tiny copper lines on the window, it will cause interference with the radio. Something to do with resistance or something (I don't really understand), but when I repaired the breaks in the copper, the interference went away.
  3. Re: Interference from Heated window switch
    Mar 2008
    Staffordshire
    I guess that kind of makes sense. Its strange how it only affects local stations, perhaps it only affects frequencies below the main BBC frequencies...
    I will have to have a look at the copper lines.
  4. Re: Interference from Heated window switch
    Apr 2007
    Yeah, I've got no idea why only certain frequencies would be affected. It's worth checking the earth to your radio too. If you have it on MW or LW and turn the rear window heater on, does the reception turn to a load of crackling?
  5. Re: Interference from Heated window switch
    134 Post(s)
    2021 Post(s)
    My Octavia does this ever since the rear window was taken out to deal with some rust. They snapped off the tags and re-soldered them but I don’t think they did it very well, I will have to try redoing it.
  6. Re: Interference from Heated window switch
    Mar 2008
    Staffordshire
    Hi Crasher... thats a coincidence!
    I had to have my rear window taken out about 4 months ago for a paint defect, so its probably the same thing. THe heated window still works but perhaps the soldered joint has greater resistance or something.
  7. Re: Interference from Heated window switch
    134 Post(s)
    2021 Post(s)
    That’s what I think, I need to get around to taking a look, too busy fixing customers cars.
  1. Heated rear window
    By pufforeek in forum Alhambra
    Last Post: 03-03-2009, 09:15 AM
  2. Radio goes off when heated window on
    By andyroo in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-12-2008, 06:47 PM
  3. Heated rear window causes radio interference
    By JAM35F in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-09-2008, 10:48 PM
  4. 1995 A4 Quattro - Heated rear screen switch
    By JDA in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-01-2008, 07:49 AM
  5. heated rear window
    By njec in forum Polo - Derby - Lupo - Fox
    Last Post: 04-12-2007, 09:30 PM
