Thread: Golf Gttdi 150 Which Oil Is Best
  1. Golf Gttdi 150 Which Oil Is Best
    Sep 2007
    I have a 2003 GTTDI 150 and was just wondering which oil is the best to use in it the PD5-40 or the Long Life 5-30 both from the VW main dealer.The reason im asking is cos i have been told if you change your oil every 6000 miles the 5-40 is fine but if you leave it for long intervels then the 5-30 is best.I know about the long life service schedule and the normal schedule but i just want to know which is the best oil for the 150 engine.
  2. Re: Golf Gttdi 150 Which Oil Is Best
    May 2008
    ESSEX
    quantum pd diesel oil 5w40 and change it every 6k
  3. Re: Golf Gttdi 150 Which Oil Is Best
    7 Post(s)
    Quote Originally Posted by dieselman580 View Post
    Agreed.
    I do mine every 5k though with standard PD spec oil (not long life) as it's easier to keep track of when.
    Think about this another way. Whilst the oil may still be within specification and will do no harm to the engine bottom end, the delicate turbo bearings cam lobes could suffer as a result of all that scratchy soot being held in suspension within the oil. This is obviously exasberated the longer the oil remians in the car. Longlife oil left in for the stated longlife periods therefore in my opinion is a big no-no.
    You may well pick up by reading other threads and posts on here that Crasher (top dog here even though he is in fact a cat) recommends as a compromise that long life be used up to 10k intervals if you need to pay for someone to service your car.
  4. Re: Golf Gttdi 150 Which Oil Is Best
    Dec 2007
    New Mills, Derbyshire
    Quote Originally Posted by Michelin View Post
    The 150's are more prone to expensive engine problems than the 130. Crasher advises that you should use VW's Quantum Longlife 3 in the 150's and change it every 6000 miles. This has (so far!) resulted in none of the engine problems apperaing in his customers 150's.
    (Apologies now if having said that causes the first failure to arrive with Crasher!!)
    150 GTI DIESEL - propper juice!!
  1. Question mpg on a golf gttdi 140 56/06
    By FAROOQS in forum Golf MK5 - 2004 - 2009
    Last Post: 23-02-2009, 01:43 AM
  2. NEW with a golf gttdi
    By spud456 in forum New Member Introductions
    Last Post: 08-05-2008, 11:55 PM
  3. Golf GTTDI 130 problem
    By cornbeef in forum Golf MK4 - 1999 - 2004
    Last Post: 21-11-2007, 10:12 AM
  4. golf gttdi 150
    By mark thompson in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 07-07-2007, 01:50 PM
  5. golf gttdi 150
    Last Post: 28-06-2007, 09:51 PM
