Thread: Audi A4 8H Airbag and Cruse control activation with VAGCOM
Results 1 to 10 of 10
Hybrid View
  1. Audi A4 8H Airbag and Cruse control activation with VAGCOM
    Jan 2009
    HI All
    I just installed a cruse control in my Audi A4 8H cabriolet (2002 model) (the physical part anyways).
    While installing It, I had to remove the steering wheel and Airbag – no big deal, you just have to remember to disconnect the battery unit while doing so.
    After refitting the steering wheel and airbag, and the airbag fault light is on – this is all expected, and just as it should be, but I don’t know how to reset it ?.
    My question is therefore, what is the “code” using VAG COM, to “reactivate/reset” the drivers steering wheel airbag? AND what is the VAG COM code for activating the Cruse control?.
    If the questions are already answered in a different thread, then I apologies, but I couldn’t find it using the search function .
    Btw, is anybody interested in a guide of how to install the audi cruse control (when I’m done)?
    Thanks in advance .
    Best regards
    R. Stroemsted.
  2. Re: Audi A4 8H Airbag and Cruse control activation with VAGCOM
    May 2008
    Using VAG-COM go to address 15 (airbags) and clear the fault codes.
  3. Re: Audi A4 8H Airbag and Cruse control activation with VAGCOM
    Jan 2009
    Quote Originally Posted by Issac Hunt View Post
    Thanks, your input did the job with the airbag lights .
    But I still can’t figure how to get the Cruise Control working?
    After my original post I found a how-to, that describes the installation in detail, and it seems to have it all covered, but I just cant seem to get the inputs working on my car. (it can be found at http://www.harddrive.plus.com/Docume...%20Control.pdf)
    I'm supposed to configure the steering wheel with the upgraded cruise control, and using VAG-COM to input:
    Option 16 (steering), 07 coding, and input:
    01041
    (I have a A4 Cabriolet, with board computer, 3 spoke sports wheel, manual transmission, and Cruise Control), and the options are (http://wiki.ross-tech.com/index.php/Audi_A4_(8E)_Steering_Wheel#Coding):
    • 0?xxx: Steering Wheel
      • 0 = Standard (without Multifunction)
      • 1 = 3-Spoke Steering Wheel (Sport Steering Wheel)
      • 2 = Multifunction Steering Wheel with Radio Control
      • 3 = Multifunction Steering Wheel with Radio/Telephone Control
      • 4 = Multifunction Steering Wheel with Radio/Telephone/Voice Control
      • 5 = Multifunction Steering Wheel with Radio/Voice Control
    • 0x?xx: Options
      • +1 = Tiptronic
    • 0xx?x: Board Computer & Cruise Control
      • 0 = Board Computer & Cruise Control not installed
      • 1 = Board Computer installed
      • 2 = Cruise Control installed
      • 4 = Board Computer & Cruise Control installed
    • 0xxx?: Rear Wiper (Chassis)
      • 1 = Rear Wiper not installed (Sedan/Cabriolet)
      • 2 = Rear Wiper installed (Avant)
    When I click ok/”Do it”, VAG-COM doesn’t store the values! Any ideas what I’m doing wrong?
    Im using VAG-COM release 311.2N, could that be the problem?
    /Regards..
  4. Re: Audi A4 8H Airbag and Cruse control activation with VAGCOM
    May 2008
    You also need to enter the login code to enable cruise in the engine ECU, Address [01] Coding [11] value 11463. I think your VAG-COM version could well be the problem. Get access to v.805 and you wont have any problems.
  5. Re: Audi A4 8H Airbag and Cruse control activation with VAGCOM
    Jan 2009
    I have done that (and thanks for the info, appreciate it)
    And that worked without any problems:
    Address 01 -------------------------------------------------------
    Controller: 8E0 909 552 M
    Component: 2.4L V6/5V G 0003
    Coding: 0011504
    Shop #: WSC 00672
    1 Fault Found:
    18107 - Powertrain Data Bus: Missing Message from Steering Wheel Electronics
    P1699 - 008 - Implausible Signal
    Readiness: 0110 1101
    The fault is caused by the missing steering wheel value, so I think all I need now, is to make the DAMN thing work with the steering wheel ..Or rather, make the car accept the 01041 code!
    Its so weird, cause I can change the value to i.e. 01011 or 01001 but I can't change the value to anything with a cruise control? (01021 or 01041) .
    If the Cruise controller was broken wouldn't I be able to change the values?
    The VAG-COM doesn’t seem to be checking for correct/working hardware in any of the other menus? So I can’t really see why this is becoming such a big problem for me.
    /Rasmus
  6. Re: Audi A4 8H Airbag and Cruse control activation with VAGCOM
    May 2008
    You may need a steering ECU that supports cruise, whats the part number of your steering ECU? You can read it with VAG-COM.
  1. airbag light on?? vagcom in the highlands???
    By stephngaz in forum Golf MK4 - 1999 - 2004
    Last Post: 01-12-2010, 01:34 PM
  2. cruise control activation code
    By huey in forum VCDS - General Questions
    Last Post: 01-01-2009, 03:38 PM
  3. Reseting airbag light with VAGCOM
    By Rampage in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-08-2008, 01:22 PM
  4. turning airbag light off with vagcom
    By mark78 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-07-2008, 06:54 PM
  5. Audi A4 Radio Activation Code
    By olgs in forum Audi A4 - Archive Topics
    Last Post: 27-10-2007, 01:01 PM
