Thread: T5 Cambelt Failure
  1. T5 Cambelt Failure
    Dec 2008
    Hi All,
    I joined yesterday as I have the pleasure of having to repair a relatives T5 Crewcab 2003 88kw. whilst he is away on holiday
    Both the cam and pump belts have failed presumably at the same time?
    So I guess that means damaged valves in the head.
    Is this type of failure common?
    I have all the info from the forum to repair, brilliant, many thanks to all contributers, Happy New Year.
    Toein
    Portlaoise
    Eire
  2. Re: T5 Cambelt Failure
    Jul 2007
    Cheshire, or my A6
    Quote Originally Posted by Toein View Post
    Hi All,
    Toein
    Portlaoise
    Eire
    Its a common failiure if the timing belt change and relevant tensioners haven't been done on time. Has your friend kept to the 60k or 4 year schedule? If this is the original belt then it was overdue!
    Best of luck... an engine re-furb on any engine after a timing belt failiure is hard work.
    Paul
  3. Re: T5 Cambelt Failure
    Dec 2008
    Hi Paul,
    Yes, belt change way overdue 73K!
    Very awkward to get at all the parts to get the head off, interestingly? I took off the thottle valve housing and it was almost 75% choked with oil and soot so performace must have been greatly affected.
    I had to buy a very long extension to reach the turbo oil drain flange from underneath, once that's off should be able to remove the head and access the damage.
    Regards
    Ian
  4. Re: T5 Cambelt Failure
    I know its a long time since this thread was on the go, But thought i would put my thought forward. Ive just bought a T5 and it has 90k on the clock and owned by 1 company it got the first 2 services and not had anymore. All it got was a top up of oil. I changed the cam belt etc and they seemed in good condition and looked like they would do another 50k . I know they all seem to look ok till they snap. Im not sure weather i was it was look on my side or bad luck on your side but it just goes to show the difference between 2 vehicles. Mine had been driven hard and not looked after and all its life to now has done short journeys.
  1. MOT Failure
    By saunders1587 in forum Polo - Derby - Lupo - Fox
    Last Post: 24-04-2008, 09:57 PM
  2. MFD failure
    By Mav2006 in forum Golf MK5 - 2004 - 2009
    Last Post: 19-04-2008, 01:14 PM
  3. Cambelt failure on 98 passat tdi 110
    By fatcatpassat in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-04-2008, 12:03 PM
  4. MOT Failure!!!!!!!
    By atell40 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-10-2007, 12:48 PM
  5. A4 avant waterpump and cambelt failure
    By michaelahill in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-04-2007, 01:58 AM
