Thread: Heated windscreen washer jets
  1. Heated windscreen washer jets
    Hi does anyone know if its possible to retrofit heated washer jets to a mkv golf?
    Reason I ask is I didn't have any squirt today - thought it might have been the cold weather freezing the jets!?
    Just bought it so it should have the genuine VW fluid (to the right concentration I hope)
    Also it would seem that unless the winter pack was specified there is no low fluid level warning so it could be that I have no fluid of course!
    Look forward to hearing from ya...
  2. Re: Heated windscreen washer jets
    Bath, Somerset
    This has been asked before recently so do a search and you should find some info.
    I imagine it is possible to fit heated washer jets but knowing how to wire them in (the heated rear window switch normaly) would be the tricky bit.
  3. Re: Heated windscreen washer jets
    Dec 2008
    Hi, i have the same problem, and i am sure mine has the winterpack as it has headlamp washers and heated seats. I think it has heated washers, but the conclusion i came to was that the water must be frozen in the tank. If you look at where it is, on mine its in front of the drivers side front wheel, i guess it just freezes and takes a while for the engine heat to defrost it, still this is only a guess. I drove about thirty miles the other day on the motorway and it then suddenly started working again.
  4. Re: Heated windscreen washer jets
    Dec 2008
    Worcestershire
    Quote Originally Posted by tim r32 mark 5 View Post
    My golf has the winter pack and as of yet I have had no trouble with the jets or bottle freezing even when the temp dropped to -6 on the way back from Wales the other week the 2 cars I traveled with a corsa and new Mini both had real trouble with the water freezing for a good 1 1/2 hours
  5. Re: Heated windscreen washer jets
    Up North
    I've got them, but wouldn't pay good money to have them on a car. Even with heated jets, the air temperature was so cold last week that water froze immediately it came into contact with the (heated!!) screen.
    My advice would be to use a good quality winter screenwash at about 25-40% strength and this will do the job for you. I've done thousands of winter miles in Scandinavia where they have screenwash so strong that the smell of it in the cabin nearly knocks you out when you hit the button! Never a problem with freezing water, even at stupidly low temperatures.
    p.s. Always read the label and do what it says on the tin. Don't use 100% strength or you risk problems with the pump and pipework.
    Driving - Shiny new E350 Estate.. Just Arrived - Aggh! a C-Max. What have I done?
    Just Gone - 2008 Passat 2.0CR TDi DSG Estate + toys, 2007 Golf GTI
    Once, cars were simple and I was smart. Now things are the other way around.
  6. Re: Heated windscreen washer jets
    Thanks for your replies, it in fact turns out that I had run out of screen wash... can't believe a low washer level indicator is an option...
    Anyhoo, I will try making the mix stronger and see what happens in the future.
  1. heated washer jets
    By sbt in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-12-2008, 01:12 PM
  2. Please Help heated washer jets
    By sarah14 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-11-2008, 08:15 PM
  3. Question heated washer jets
    Last Post: 30-10-2008, 11:05 PM
  4. Heated Washer Jets for Windscreen
    By Polo Mint in forum Polo - Derby - Lupo - Fox
    Last Post: 21-02-2008, 05:12 PM
  5. Heated windscreen washer jets?
    By Zub in forum Passat - Archive Topics
    Last Post: 02-03-2007, 04:55 PM
