Thread: Window Regulator please read
  1. Window Regulator please read
    hiya all , this is a long shot but worth a try.
    has anyone got a broken regulator as i only need one of the green lifter guides that slide in the side runners.
    for a 99 plate A3 front doors they are not handed so either door would do.
    thanks andy
  2. Re: Window Regulator please read
    Jan 2009
    Kent
    I understand from a few messages posted in other forums that the part you need can be sourced for under a fiver - the part number is 4B0-837-463-B. I understand that the B is very important. There is a site in French with an explanation of how to do it (if you google the part number and look on s3-passion.com) and there is also an american version but that is on a A6. Need to do mine (late '02 S3) so when I get the part and have a go I will add another post.
    Oh by the way, the replacement part I understand is much stronger and it has changed colour so there obviously has been an issue with the fragile nature of the item. My local dealer wanted £270 for a regulator plus fitting)
    Later
    Paul
  3. Re: Window Regulator please read
    thanks for that
  4. Re: Window Regulator please read
    Jan 2009
    Kent
    Done a bit more trawling through the forums. Came up with this from an A6 post - thanks to Chris who put it there.
    http://www.piglet-net.net/tech/cars/a3-window.html
    All you ever wanted to know about doing A3 windows!
    Good luck
    Paul
  1. window regulator
    By dmnmulvenna@yah in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 01-01-2009, 03:52 PM
  2. window regulator
    By ricechrispea in forum Golf MK4 - 1999 - 2004
    Last Post: 25-10-2008, 08:06 PM
  3. How To replace LHF (nsf) window regulator?
    By joolsedwards in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-07-2008, 04:23 PM
  4. b5 window regulator
    By stubbsy in forum Audi A4 - Archive Topics
    Last Post: 28-02-2007, 10:09 AM
  5. Audi 100 Window Regulator
    By cheedmonkey in forum 100 - 200 - Turbo - 100 S4
    Last Post: 23-09-2006, 03:45 PM
